 Post subject: cooling
PostPosted: Wed Jan 10, 2007 1:33 pm
Whats the best radiator 4 the money to cool a 383sbc stroker? aluminum? what size or brand even? any modles. any info helps. thanx.
PostPosted: Wed Jan 10, 2007 2:07 pm
there is a typical sized aluminum cross flow radiator most everyone uses. 19" x 22" or something close to that. $149 was the cheapest I found them online.
I made a thread dealing with this 6 months ago.
1977 Chevy Luv
350/TH350
PostPosted: Wed Jan 10, 2007 3:34 pm
Speedway motors has the least expensive unit available right now. It's a 19" by 22" unit that seems to be pretty popular with the LUV crowd. If you're going to run an automatic transmission, you'll need to get a trans cooler because the Speedway radiator doesn't have provisions for trans cooling.
PostPosted: Thu Jan 11, 2007 9:10 pm
so were can i get one and how well douse it cool?
PostPosted: Thu Jan 11, 2007 9:30 pm
http://www.speedwaymotors.com/p/3557,34 ... ators.html
Nobody has made any complaints that has done a V-8 swap yet.
PostPosted: Thu Jan 11, 2007 9:32 pm
sweet! thanx
PostPosted: Fri Jan 12, 2007 11:00 am
Put as much radiator as you can . I have the griffin 19x22 . I have a17" flex fan and a 160* t-stat . Have not driven it through a summer yet .
PostPosted: Fri Jan 12, 2007 12:46 pm
whats the hottest its got, in what traffic and how hot was it outside?
PostPosted: Sat Jan 13, 2007 8:48 pm
Last night I was sitting in line at the track waiting to pay it was about 75 and humid and it never got over 180 . It idled about 15 minutes bumper to bumper . I have plans to reinstall the A/C before summer and that will be a real test .
PostPosted: Sat Jan 13, 2007 10:30 pm
how about engine oil cooler.
PostPosted: Sun Jan 14, 2007 2:37 pm
You shouldn't need one. I had problems overheating with a stock radiator, went to the aluminum radiaor and have had no problems. Mine will idle all day long in 100 degree weather. It has stayed cool in summer for me when it was to hot to ride in the cab.
