It is currently Mon May 25, 2026 4:31 pm
PostPosted: Thu Dec 21, 2006 10:15 pm
8)
I'm finally a member, i have an 81 luv longbed 2wd, its been in my family since 1985 and the ignition went out on it about 2 years ago, ive just begun to get it together,(engine rebuilt 5k miles ago) it has a g180 block and a g200 head stock cam(replaced 2k miles ago) hedman header, older weber carb and a thrush muffler, also 15x8 ralleys w/ 215 50's
here is a list of parts i have waiting to be installed.
crane cams xr700 ignition box w/optical trigger
accell super stock coil
msd super conductor wires
weber 38 dgas carb
flowmaster 30 series
heres is a list of needs
a bed (long) mine is fubar.
passenger side window
bench seat
driver side front fender
grill
If anyone knows where i can get any of these please let me know.
I want to get an offy manifold and a delta cam
also a 5 spd and possibly a new rear end.
I live in ukiah california so if anyone wants to come help put this beast back together feel free. I'll have pictures up soon.
PostPosted: Thu Dec 21, 2006 10:26 pm
I have a 5 speed out of a early 80's v-6 camaro,not sure if you could make it fit,but i'll make you a good deal on it if interested.I race in yreka in the summertime and you could pick it up there if you want to.
72 luv v-8 owned since 16!
240" rear engine dragster
[color=#FF8000]
29 dodge 4 dr sedan (project)
PostPosted: Fri Dec 22, 2006 12:08 am
How about......
Grill
http://cgi.ebay.com/ebaymotors/GRILLE-c ... otohosting
So far no luck on anything else
PostPosted: Fri Dec 22, 2006 9:59 am
Nice source for lights,fenders, and hoods!!!
You might also try http://car-part.com/
'78 1.8L 4-speed Fleetside
Image Image
PostPosted: Fri Dec 22, 2006 5:31 pm
http://www.keystone-auto.com/
What we use alot at the body shop, They will prob have what you need as well.
PostPosted: Fri Dec 22, 2006 7:59 pm
You can actually buy new grills:
http://www.chevypartstore.com/chevy-luv ... parts.html
PostPosted: Fri Dec 22, 2006 11:14 pm
i wouldnt go with the 38 weber on the 1.8. it a little too much. youd be good with a properly jetted 32/32. also, all the igntion stuff you talk about isnt going to make a very noticable difference in power.
since it an 81 im pretty sure it has electronic igniton, so hookin up an MSD box would be and easy task. the box along with a MSD coil for an electronic igintion system would be more than better for your application.
on my truck (84 pup, 1.9l impulse engine, 32/32weber) i run and MSD 6A box on the stock coil. i also have MSD 8.5mm wires. when i put that stuff on, it made all the difference in the world. it would start easier, straight up run better and it wouldnt miss like it did before. the MSD box also eliminated the high RPM miss i had.
these are all just some suggestions. dont want to make any decisions for ya.
:D
PostPosted: Sat Dec 23, 2006 12:21 am
I already have the weber 38 and the crane ignition and the accel coil.
I dont have the adapter, linkage or air cleaner for the carb, when i ordered it i didnt think i'd need it since it had a weber on it already.
but this one fits on the intake manifold as is, I guess it was made for an old fiat and was sold smog legal in california back in 93 i beleive. :D
what do i do :?:
PostPosted: Sat Dec 23, 2006 12:55 am
i dont think the weber is going to fit on the stock intake without an adapter. a weber will fit on a weber intake, but not the other way. if you already have a weber than you have an adapter already.
cool deal on the ignition parts. id like to see how you setup the crank trigger. might shed some light on how i can get a megasquirt to control my fuel and spark with my FI intake.
PostPosted: Sat Dec 23, 2006 1:10 am
The smog legal weber for a nissan is a direct bolt on for a luv,I put one on my 72 back in the day..... (1992)
[color=#FF8000]
PostPosted: Sat Dec 23, 2006 1:35 am
when i had realized that i didnt have the same carb i called the place i bought it from and told him the number thats stamped on my old carb.
he said it was originally for a fiat spyder.
as for a nissan carb fitting on your 72.....not sure that the intake is the same as my 81 but it might bolt up...never know.
we will see how the ignition goes sometime in january weather permitting, so its not likely. :lol:
PostPosted: Sat Dec 23, 2006 2:07 am
heres some pics.
yeah its ugly but its mine
also 1984 ranger 2.8 v6 5spd 2wd
for sale $1500 :wink: :wink:
PostPosted: Sat Dec 23, 2006 2:08 am
oops here they are
http://pg.photos.yahoo.com/ph/fatboy_sl ... .dir=/cd8f
