It is currently Mon May 25, 2026 11:25 pm
PostPosted: Tue Dec 12, 2006 8:39 pm
So I am going to have the S-10 rear axle, so it is time to buy new rims, and I wanted to know, would a 15 x 7 with a 4 inch backspacing be enough to tuck underneath the fender ?
-Austin
PostPosted: Tue Dec 12, 2006 11:11 pm
Hyperwrx is going thru this same thing. Read up on his progress to get an idea of whats involved
http://forums.luvtruck.com/viewtopic.ph ... 45&start=0
PostPosted: Tue Dec 12, 2006 11:17 pm
I have looked through that discussion, and it seems that everyone is chatting about deep dish rims and such, but I already asked there and there is no response to my question. I just want 7 inch rallys :D
-Austin
PostPosted: Tue Dec 12, 2006 11:29 pm
It looks like you'll have about an inch or so for the tire to fit inside the fender. This means you'll need to run a narrow tire. If you have a stock motor truck, it shouldn't be a problem. If you have a V-6 or V-8 powered truck, you'll have hook up problems getting the power to the pavement.
PostPosted: Wed Dec 13, 2006 1:44 am
Eh, I have a SBC in it, but its a boulevard cruiser, not a drag truck, so if I run 215-235 its not a big deal for me. I think 225 would be ok
-Austin
PostPosted: Thu Dec 14, 2006 11:22 am
By my calculations you are fine. You'll have room to spare.
 Post subject: backspacing
PostPosted: Thu Dec 14, 2006 7:52 pm
Location: Colonial Beach VA. If i am not home or at the track then I am probably at HOOTERS!
i have a 9" in mine and it measures 53 1/2'' i am running 15x8 welds off of a 68-74 nova meaning they have all the dish inward but the fender arches are stock
74 LUV 355 Bracket Car
WANTED DEAD OR ALIVE 68-74 NOVAS
TOO MUCH IS NOT ENOUGH!!!!!!!!!!!!!!
PostPosted: Fri Dec 15, 2006 7:34 pm
The widest wheel on an s-10 10 bolt rear end that will fit under a non-modified Luv fender is a 15 x 10 with 5.5" backspacing.
From your drum mounting surface to the frame measures 7.25".
From your frame to the top of your fender is 11.25".
With that backspacing you have about .75" or 3/4 of an inch between your tire and the frame on the inside of the wheel/rim. I am alotting .75 for the tire to stick out beyond the rim.
The tight area is the upper fender. Your 10" wheel + .75" x 2 = 11.25 <-- the exact stock space avaliable. Luv upper fender has a small 1/4 rolled edge/lip. I'm thinking I'll have to cut that off.
We'll see. Should look mean with the fender completely filled from side to side with rubber.
PostPosted: Fri Dec 15, 2006 7:48 pm
Hyper: Did you take into account tire flex, and such like that ? In no way am I doggin' your data, because it all seems really well done, I just wanted to make sure you didn't get into a situation and :evil: look like that.
-Austin
PostPosted: Fri Dec 15, 2006 7:52 pm
-Austin
I did not take into account flex. You are meaning side to side movement like when you are cornering?
I have .75 on the inside, outside is way closer.
1977 Chevy Luv
350/TH350
PostPosted: Fri Dec 15, 2006 8:00 pm
Yeah tire movement side to side when cornering, unless using a really low profile series tire could be an issue. . . Like the dragsters plan for 'tire growth' on launch when the tires get taller, street cars have to worry about the side to side, and it sounds like you are working with pretty close tolerances.
-Austin
PostPosted: Wed Dec 20, 2006 12:52 am
I have about 1/2 to 3/4 inch clearence between outside fender and tire and have no issues. I run a 10.5 sportman pro that wrinkles the side wall on launch. I guess it would depend how much your tire flexes and how far the tire fits up in the fender well.
Users browsing this forum: Bing [Bot] and 23 guests
