It is currently Tue Jun 30, 2026 3:33 am
 Post subject: S-10 axle upgrades
PostPosted: Tue Nov 28, 2006 7:24 pm
I know that a ford 9 inch or GM 12 bolt is the way to go for a rear end if u r doing a v-8 conversion, but can a built 7.5 handle some power?
grudd
'69 mustang
'78 luv
'68 Lemans
PostPosted: Tue Nov 28, 2006 8:43 pm
They Can Handle Round and About Like 400 HP W/O Any Hard Launches. They Can Only Handle A Few Times Dead Hooking and They Explode Normally.
PostPosted: Tue Nov 28, 2006 9:03 pm
They are not very strong . I watched 6 Camaros leave the track on roll back wrecker the other day . The weather is getting colder and more power is put to cold( 60 * and below ) axle parts and bang . just a suggestion if you don't drive to the track , take your jack and stands and warm the rear axle in cold weather . Sorry to get off the original subject , I would say 9" , 10 bolt 8.5 , AMC 20 , Dana 44 or of coarse Dana 60 . I'm just not a big 12 bolt car axle fan .
PostPosted: Tue Nov 28, 2006 9:20 pm
i saw that moser makes aftermarket axles and t/A performance makes a support cover for the 7.5.
'78 Luv 1.8, soon to be 350
'69 mustang 302
'68 lemans 455
PostPosted: Tue Nov 28, 2006 9:35 pm
There's an article in the Jan 2007 edition of Chevy Performance on building a 10 bolt, 8.2 inch axle to survive. The theory is that a smaller ring and pinion set is easier to spin that a larger one.
The thing that slows me down on the project is that they stayed with the c-clip design.
PostPosted: Tue Nov 28, 2006 9:48 pm
yeah, but im just wondering if one is set up properly with a good ring and pinion, strong axles, support cover, and posi, could it handle a high 11 mid 12 second luv truck?
'69 mustang 302
'68 lemans 455
PostPosted: Tue Nov 28, 2006 10:42 pm
grudd... i've got one sitting around if you wanna play with it.. i believe it currently has 2:73 gears and was from under a v-8 LUV
PostPosted: Tue Nov 28, 2006 10:59 pm
Grudd, a 9 inch with stock axles will be at least as strong as an upgraded axle 7.5 Most of the older truck 9 inches come with 31 spline axles, They can be shortened easily. Having the housing and axles shortened and redrilled if you want a smaller bolt pattern costs about the same as a new set of 7.5 axles, at least around my neck of the woods. The advantage is you have the c-clips eliminated and bigger brakes with the 9 inch. If you upgrate the 7.5 with c-clip eliminators, you still have to modify the housing, so there is the cost involved with that also. You can have a good rear for the same price and still be able top upgrade it later, or you can max the 7.5 and still be marginal. Just a thought.
PostPosted: Wed Nov 29, 2006 10:04 pm
I have to agree with mytmouz. That's a lot of work to try and make a 7.5 handle some power. A Ford 9" is way easier to build, stock setup can handle quite a bit. And if you want, you can swap out the 3rd member in a couple of hrs and only need a gasket. Upgrades are cheap (compared to other axle assys).
But if you're dead set to give the 7.5 a run, then rock and roll man!
PostPosted: Thu Nov 30, 2006 9:15 pm
I have used the s10 rear land speed racing.I am going to a 9 inch.
400hp + good track + good tires = $ in fixing all that gets broke. The 9 inch will last. cheaper ,stronger, the s10 parts can work but will cost more
PostPosted: Fri Dec 08, 2006 2:05 pm
I can see running an S-10 for land speed. The less mechanical drag, the better. It has to put up with a power load but not instantainiously like a hard launch at the dragstrip.
It sounds like you decided to upgrade for longevity reasons. I guess you'll have to add more power to the motor to compensate for the extra mechanical drag... Bummer :D
PostPosted: Sat Dec 09, 2006 4:31 pm
Going to 9in so with 4-500 hp at 6000 rpms I have no issues.The s-10 bearings axle may not like 170+ mph. The one I have is cleared to 200+ but at those speeds when things go bad it is REAL Bad .A broke drive shaft means at a min motor,trans,rear+body work.
I trust the s-10 rear to a point but not past it
