It is currently Sun Jun 28, 2026 1:43 am
PostPosted: Wed Sep 13, 2006 10:28 pm
Weld Draglite wheels don't come in 6 lug so I am forced to use an adapter to get to a 5 lug standard on my 2 front tires (rear 2 are on a s-10 10 bolt 7.5 rear end so I'm ok there).
Anyone around have a reputable online store they've bought these from?
Best I have found is $99.75
http://www.adaptitusa.com/index.asp?PageAction=VIEWPROD&ProdID=138
These adapters are 2" wide so my front tire will be pushed outward 2". I offset this by getting my front wheels with a greater (deeper) backspacing?
Anyone know what stock backspacing is on the front rim of a 77 Luv?
Thanks in advance. This forum has helped me so much.
PostPosted: Thu Sep 21, 2006 2:30 pm
Japanese Redneck
bummer, Weld used to make 6 lugger drag lites cuz i used to have some. I would consider a different brand of wheel. Weld should come back out with 6 luggers because a lot of todays trucks and SUV's have them.
1978 LUV Truck 2WD
450 "Small Block" Chevy
3.70 Ford 9
28x10 Goodyears
PostPosted: Sat Oct 14, 2006 10:12 pm
Actually if you use the spindle and rotors from an earlier Toyota they will bold right on the luv trucks. I used to have a set on a 74 luv drag truck. And it will give you a 5 on 4 1/2 lug patern like a ford. Good luck with the project.
PostPosted: Sat Oct 14, 2006 10:15 pm
which calipers would you use with the toyo rotors and spindles
PostPosted: Sat Oct 14, 2006 10:43 pm
We used everything off the Toyota ..... Calipers and all....
PostPosted: Sat Oct 14, 2006 11:06 pm
thanks for the info :wink:
PostPosted: Sat Oct 14, 2006 11:27 pm
Have you some pictures we can look at? What year toyota parts?
PostPosted: Sun Oct 15, 2006 7:45 am
I do not have any pictures of the build. All I have is one of the truck almost finished. And I have no scanner. The toyota truck was early 80's.
 Post subject: bolt pattern
PostPosted: Tue Oct 24, 2006 4:44 pm
Location: Colonial Beach VA. If i am not home or at the track then I am probably at HOOTERS!
i just centerd a 5 lug wheel on my brake drum TAKE YOUR TIME and marked and drilled then got some moroso long studs and welded them in hope this helps
74 LUV 355 Bracket Car
WANTED DEAD OR ALIVE 68-74 NOVAS
TOO MUCH IS NOT ENOUGH!!!!!!!!!!!!!!
Last edited by drummondracing on Wed Oct 25, 2006 3:29 pm, edited 1 time in total.
PostPosted: Tue Oct 24, 2006 5:15 pm
I purchased a set of 6 to 5 lug adapters last week. I'll post pictures and my thoughts once they arrive
 Post subject: adapters
PostPosted: Tue Oct 24, 2006 5:25 pm
the problem with the adapters is they will make the wheels stick out about another 1'' or more
PostPosted: Tue Oct 24, 2006 6:04 pm
Mine came in today and I went out and 'tried' mounting them. You are correct.. they look terrible. I have a 5 inch Wild Drag lite rim even and they're still sticking out so far I wont use them. $150 down the drain.
DAMN IT
PostPosted: Wed Oct 25, 2006 3:28 pm
i thought so i have weld 3 1/2 draglites on the front of mine and on the stock drums they are dead even with the fenders.like i said it is not too hard to drill your 6 lug drims to 5 lug
PostPosted: Wed Oct 25, 2006 5:11 pm
drummondracing: you have a PM
 Post subject: Re: adapters
PostPosted: Thu Oct 26, 2006 4:51 am
Thats if youve got drums on the front. if youve got discs you cant redrill.
I wouldnt use spacers they load up the studs too much.
Bob.
PostPosted: Thu Oct 26, 2006 5:23 am
Rodeobob, the stock rotors on my truck are drilled for the 5 on 4 1/2 lug pattern. It's a 2 piece hub, one of the new lugs goes through the outer edge of the bolt that mates the two halves. It's not in the shank of the bolt so its not causing a problem. I don't think I'd try to use the more common 5 on 4 3/4 pattern as you will get into more of the bolts.
PostPosted: Thu Oct 26, 2006 5:55 am
My bad, i should have said should not instead of can not.
Take me a pic of this redrilling if you can. Id be interested to see it.
Cheers, Bob.
PostPosted: Thu Oct 26, 2006 6:33 am
I Hace roters not drums so it doesnt help
 Post subject: rotors
PostPosted: Thu Oct 26, 2006 4:51 pm
i heard strange will do it but i am sure it is pricy
PostPosted: Thu Oct 26, 2006 8:14 pm
i know moser won't redrill .
T.J. white has 1994 toyota rotors on his , but these will take extensive machine work to make happen . They are not a bolt on by any means.
I would be interested in hearing the "early 80's toyota rotor swap" .
This leaves Aero space and ? . I guess they are the only bolt on swap.
