It is currently Fri Jun 26, 2026 6:33 am
 Post subject: 700r4
PostPosted: Fri May 12, 2006 4:15 pm
what all has to be done to use a 700r4 in a v-8 conversion?
PostPosted: Fri May 12, 2006 7:07 pm
i am guessing a custom driveshaft. But there arent many 700 r4's in use with the v8 swap, they seem to be kind weak. i am sure they can be built to withstand lots of power, but the favorite is the ol' 350/350 :twisted:
!!!FINALLY!!!
-1977 Luv mikado
PostPosted: Fri May 12, 2006 11:08 pm
well all the ones i looked at said they could handle 500-550hp and my v-8 is no more than 350hp so it should be fine i would think
PostPosted: Fri May 12, 2006 11:25 pm
then all you need to do is fab up the mounts and run it.
PostPosted: Fri May 12, 2006 11:28 pm
I think ben is running a 700r4,he could probably answer all your questions
''''Bottles are for babies''''
77 luv all original with working factory a/c
50,000 original miles
74 chevy luv 1/8th mile
bracket racer
99 chevy silverado supercharged 425hp daily driver.
PostPosted: Fri May 12, 2006 11:35 pm
Ben has ran 700's but after smoking a few he went with a 350 or 400
PostPosted: Sat May 13, 2006 6:51 pm
PostPosted: Sat May 13, 2006 6:52 pm
PostPosted: Sat May 13, 2006 6:53 pm
PostPosted: Sat May 13, 2006 6:54 pm
PostPosted: Sun May 14, 2006 7:48 am
see the reason i liked the 700r4 so much is its a 4 speed and the final gear is .67, and im gonna drag it down at the airway heights drag strip but im also gonna use it for my daily driver so yea.........................any otha info would be great and i also heard that the 87' and up 700's were a lot stronger and didnt have problems with bein weak? ne one know bout that? thanks...
PostPosted: Tue May 16, 2006 1:04 am
longevity for my first 87 1/2 ton 700-4 was 275k miles. It just quit and gave up the ghost with only fluid changes and filter changes. The new crate one from Chevy has only 125k and on cold days(around 32+/-) it can't make up it's mind what gear it wants to be in whether going uphill or down. So I got lucky with the first one. Don't even go to Colorado in the winter anymore, can't trust it. I hope this is a fluke.
Let me xray you, you will feel better.
PostPosted: Tue Jun 20, 2006 6:59 am
:smt115
PostPosted: Tue Jun 20, 2006 7:06 am
:smt115 :smt100 Look for a 4l60 out of 90-95 pickup/vans they are a stronger version of the 700r4,use a TCI kit witch doubles the clutchs in the over drive pack.And you have got to make sure that the TVS cable is adjusted right.
PostPosted: Tue Jun 20, 2006 7:20 pm
I was under the impression that 4L60s are the same thing as the 700R4s, and 4L60Es are what you want if you want something more stout. But then you need to run a computer...
PostPosted: Tue Jun 20, 2006 7:30 pm
4l60e= 700r4 electronic. 4l80e=th400 overdrive
PostPosted: Wed Jun 21, 2006 3:44 am
yeah thats my basic understnading of things. I was under the impression though that major improvements were not made untill the tranny (4l60/700r4) went electronic.
PostPosted: Wed Jun 21, 2006 6:56 am
The 700r4s in 90 up had some internal parts upgraded for heaver use in pickups and vans so it was called a 4l60 instead of a 700r4 upgrade. In 95-96 GM then made it an electronic 4l60e. You can buy these trans in like new condition from GM, a good place is Sallee Chevrolet in MiltonFreewater Ore.as well as about any engine or speed goody for Chevys there are. :idea: Get on there web site you can't go wrong as there pricing is hard to beat. :roll:
PostPosted: Wed Jun 21, 2006 4:39 pm
Sallee is good for a new one. Remember if up grading a old one things can get expensive real quick. I had one break a rear planet shaft and tore it down. Looked like new at 103,000. Bought the upgaded 5 gear front and rear planet sets .05 pressure solinoid, beast heavy duty sun shell & out put shaft, 10 vain pump, new converter, corvette billit servo, all new soft parts and fluid and had $1500 in parts. Bowtie overdrives is anouther good site to check out.
PostPosted: Wed Jun 21, 2006 10:00 pm
Japanese Redneck
a nice advantage besides the .67 OD gear is the 3.06:1 first gear. that makes for a nice launch.
put a stout shift kit in it, toss the wavy plates in the trash and use additional fiber and metal to replace them. use a HD or Corvette Servo, a 10 vein pump is a necessity (early had 7 vein). kevlar (red) band, kevlar plates, etc. i believe u would have to redrill ur trans adapter plate and shorten the driveshaft as the 4L60 (E) is 2" longer than a TH350. a disadvantage is that you cant really go super loose on the converter without sacraficing the trans a little. I wouldnt go any looser than 3600 stall.
A lot of racers use a 200R4 out of a grand national and beef them up with all aftermarket internals. they are supposedly stronger than a TH 400 but less parasitic (TH 400 will lose you about .2 sec in the quarter mile due to heavy rotating mass)
1978 LUV Truck 2WD
450 "Small Block" Chevy
3.70 Ford 9
28x10 Goodyears
