It is currently Tue Jun 30, 2026 10:38 pm
 Post subject: Re: engine choice
PostPosted: Thu May 28, 2009 9:05 am
yup
got the disc brake upgrade from Ctmandu ordered the master from an 80 luv
looking for some brake lines (any suggestions appreciated) you say suspension upgrades? like welding a filler plate on the lower control arms? or switching to poly bushings (if i can find them)
recently purchased 72 luv truck
1970 dodge charger- 500ci 5 speed
ram big horn 5.7 hemi
PostPosted: Thu May 28, 2009 9:18 am
I got a flare tool set from Napa pretty cheap and just make my own lines. It's pretty easy...
PostPosted: Thu May 28, 2009 9:56 am
figured that .
was looking for the rubber lines
PostPosted: Thu May 28, 2009 10:09 am
I'm jealous of your engine swap. I have a '72 and if the motor ever gives up I may consider something similar. Problem is it runs too good now to do anything to. Good luck on your swap, keep us updated.
PostPosted: Thu May 28, 2009 10:49 am
Moparich wrote:
figured that .
Ahh, I bought new ones for mine from Carquest...
PostPosted: Thu May 28, 2009 11:50 am
the suspention i read somewhere on the pre 76 and even i think the 76 77 LUVs had somethign that made the handling feel sloppy that was fixed in the later years, but it might have been the bushings. And i know one thing is that putting poly bushings will help, I just cant quite put my finger on what it was that I read about.... Mabye some one here can help shed some light for me...
PostPosted: Thu May 28, 2009 3:11 pm
i know it could definetley use a bigger sway bar.
maybe someone could tell me where i could get a bigger sway bar and some poly bushings for the control arms and forward strut bar
PostPosted: Thu May 28, 2009 7:15 pm
what about a 4cz1 turbo out of a late 80's impulse? thats the route I'm thinking about going,keep it isuzu lol
76 mikado project,mean green
PostPosted: Fri May 29, 2009 12:25 am
Sway bar, check with addco, I think they are in San Diego area.
PostPosted: Mon Jun 01, 2009 7:01 pm
Old Rob
you did a rack and pinion conversion?
did you just add the rack? if so what was the critical dimension for the rack width. i got this power rack from a 200sx really looks like it would fit.
should the rack dim for the inner tie rods match the luv dims exactly or is there room for fudge :esurprised
