It is currently Mon May 25, 2026 8:07 pm
 Post subject: Chevy V6
PostPosted: Mon Feb 26, 2007 8:50 am
well i got my 2wd luv home.
and in it was a Buick v6.But it needs to be redone top and bottom the guy said.
So i thought about putting a chevy v6 in it
Will i have any trouble with the distributor or anything like that?
PostPosted: Tue Feb 27, 2007 1:43 am
Why not find another Builck Fireball in a junkyard to use? There were LOTS of models in the late 70's early 80's that used it.
1978 shortbed fleetside, th350, Fireball 231 Even Fire V6, Edelbrock 500CFM Performer with Edelbrock intake. Workin' Truck.
PostPosted: Wed Feb 28, 2007 7:47 am
Other than the 4.3 chev motor there are no other chevy V6's that are either worth putting in or easy example 2.8 :smt018 to heavy for the power it makes it can be made to make power but cost to much and the 4.3 becomes cheap,another motor to look at though is the 93 up f-body 3.4 with the 5spd if you can do the conversion with the computer this light weight little motor would be a perfect setup.(look how good they do in a 3500lbs f-body)I thought of doing this setup my self if i can fine another truck in good shape.
