It is currently Mon May 25, 2026 7:30 am
 Post subject: V-8 temp sending unit
PostPosted: Fri Aug 11, 2006 9:49 pm
wondering what temp sending unit is used with v-8 conversion. I have a gauge. Factory luv unit does not fit in manifold well.
PostPosted: Fri Aug 11, 2006 10:51 pm
I used the stock one and adapted it to the head in between the exhaust ports on the side.
PostPosted: Fri Aug 11, 2006 10:56 pm
Most will run an aftermarket gage like Autometer. It would be more accurate.
If you are able to adapt the stock sensor to the V-8, it may not read the same as the original 4 cyl. If the 4 cyl temp reading rode at the low end of the white range of the stock gage and the V-8 rides at the high end, would it be 10, 15, 20 degrees higher? You wouldn't know the exact temp (degrees).
PostPosted: Sat Aug 12, 2006 12:52 am
I used a extra water temp sending unit off of my Ford FE that I had laying around, and it seems to be pretty accurate. I got it working using the stock temp. gauge. I'm not sure what intake your using but I'm running a holley dual plane. I just put the sensor from the FE in one of those holes up next to the thermostat. I could get a picture tommorow if you'd like?
1975 V8 Luv
1980 Bagged Luv
PostPosted: Sat Aug 12, 2006 10:23 am
I will have aftermarket gauges to monitor the exact temp. I just want the factory gauge to function also. I hate having things not work properly.
I am running a preformer rpm air gap vortec . I would like to try the old ford sender if it worked for you . I have plenty of water ports to choose from. I already have the aftermarket gauge sending unit mounted. I also have 2 oil pressure sending units. One for the light and the other for the aftermarket gauge. You don't always look at the gauge, but that light comes on you know it.
