It is currently Mon May 25, 2026 2:31 pm
 Post subject: Manual Transmission
PostPosted: Wed Feb 01, 2006 8:11 pm
Undefeated in Trivia
Is anyone else running/planning on running an SM465 transmission (granny 4-speed)?
PostPosted: Thu Feb 02, 2006 4:26 am
Swap Specialist Mod
im not runnin one myself, but a friend of mine has a international truck with one in it. what are you wanting to know?
PostPosted: Thu Feb 02, 2006 6:03 am
I was just curious. I was readin' Hooker v8 swap instructions, and the muncie 4 speed (sm465) works with the hooker trans mount bracket :-D
PostPosted: Fri Feb 03, 2006 2:22 am
Swap Specialist Mod
well there a problem about what you said. the muncie tranny that the hooker kit instructions is talkin about is the 2wd one, like a m20 m21 and m22. those are side operated trannies that have the linkage on the sides. the sm465 is a top loader tranny that is a whole hell of alot bigger than a muncie.
but that is besides the point. you can use any tranny with the hooker mounts. you just need to make a homade tranny/TC mount that will correspond with the motor mounts.
PostPosted: Fri Feb 03, 2006 2:32 am
if those mounts will hold a th350 or th400 then they will hold the muncie sm465 too. Thats the beuty of older chevs, the interchangeability is rediculouse.
