It is currently Sun May 24, 2026 10:24 pm
 Post subject: 4.3 V6 w/ TH 200
PostPosted: Tue Jul 03, 2012 10:24 am
I have a 1979 LUV 1.8L/ TH200.… Would a 4.3L bolt up to the original TH200 aside from the motor mounts?
... Good, you've located the problem; step 2 is washing it off.
 Post subject: Re: 4.3 V6 w/ TH 200
PostPosted: Tue Jul 03, 2012 11:05 am
no. different bolt patterns. TH350s are pretty easy to come by cheap though. And the stock shifter will work with it too.
PostPosted: Tue Jul 03, 2012 11:28 am
Good to know... I know the TH350 is longer so I would have to cut the driveline...
Would the 600R4 and driveline from a shortbed S-10 fit? Or would the driveline still
Have to be shortened?
PostPosted: Tue Jul 03, 2012 11:41 am
It would have to be shortened.
PostPosted: Wed Jul 04, 2012 10:56 am
Any Izuzu engine/ tranny swaps to keep in mind?
PostPosted: Wed Jul 04, 2012 11:46 am
Depends on what you're wanting to do with it and your budget. The 4.3 swap is relatively common now, but for the same amount of headache, you can put in a 305 or 350.
With just about any swap you do, you're going to have headaches, just different ones. Getting a driveshaft shortened isn't that big of a deal.
Users browsing this forum: Bing [Bot] and 31 guests
