It is currently Sun May 24, 2026 11:54 pm
PostPosted: Sat Feb 12, 2011 10:20 pm
It looks correct. Just wondering
http://watertown.craigslist.org/pts/2209427361.html
PostPosted: Sun Feb 13, 2011 8:41 am
I doubt it, to fit your LUV it must be an Isuzu MSG-5 w/cable clutch from a vehicle with either a 1.9 or 2.3 engine. As far as I know Rodeo's never came with the 2.3 4cyl, only the 2.6 or v-6. 2wd Rodeo's also used BW T-5 trannies in some applications, don't know if they were ever matched to a 4cyl or not.
PostPosted: Sun Feb 13, 2011 10:06 am
Great... thankyou for your isuzu wisdom.
Jeremy
PostPosted: Mon Feb 14, 2011 12:03 am
there are a hand full of very early 2WD amigos with it...
also theres "a few" rear drive Isuzu cars with the same trans, just a 20% O\D not a 14.5% cinda hard to come by :!:
in the MSG 5speeds, 1986 up to 1995 is up-graded compared to a 81/85 trans.
81/85 is 17 spline, 86/95 is 26 spline on the out put.
no matter how the 81/85 are treated, they still give up over time with the lower rpm/higher torque of the diesel.
faluers are less with the gassers but still lugging in 5th is not advisable.
86trooperT/D 2.2
84 L\B 4x4Diesel LS 2.2
86 L\B 4X4 gas 5 speed 2.3
