It is currently Mon May 25, 2026 1:27 am
 Post subject: 4ZE1 2.6L Engine swap
PostPosted: Mon Sep 27, 2010 1:34 pm
I was wondering if the 88-92 4ZE1 engine would bolt up to the stock LUV 4 speed tranny. If so wat all upgrades would i need to do to put it in my '80 LUV
PostPosted: Mon Sep 27, 2010 6:35 pm
search. and why would you want a 4 speed on a larger motor? id get a 5 speed if you are gonna do all that work
PostPosted: Mon Sep 27, 2010 8:40 pm
You will need a 2.3 engine plate and flywheel and a 2wd oil pan. Use the stock Luv clutch- same as for a 2.3. You will need a complete 2.6 engine- motor mounts and all accessories, manifolds- things like that. Probably a larger radiator. Firewall mods to clear the distributor. You will need a 2.3 intake & carb unless you plan to use the EFI.
PostPosted: Mon Sep 27, 2010 11:35 pm
the reason i want the 4 speed is because mine is 4 wheel drive and id like to keep same drivetrain and if i keep the EFI how hard is it to install with the ecm?
Users browsing this forum: Google [Bot] and 20 guests
