It is currently Mon May 25, 2026 10:01 am
PostPosted: Tue Jun 10, 2008 6:10 pm
O.K., so i got tired of searching and just have a quick question if anyone happens to know.
I already know i am getting a 1st gen s10 rear for the luv, to convert the rear to 5 lug and to also lower the rpms and raise top speed for hightway.
Guess what i need to know is what my current gearing is, and what gear ratio to look for in the s10 axles.
Does anyone know how or where to find what ratio i currently have? It's a 76, 2wd if that helps any. I'm assuming i should go to 2.x gears but not sure if I'm right.
Gary
PostPosted: Wed Jun 11, 2008 6:57 am
http://www.nastyz28.com/camaro/zsusp.html#rearaxle
Also
http://faq.dakota-truck.net/Transmission_and_Gears/find_gear_ratio.html
And finally
http://www.allfordmustangs.com/forums/5-0l-tech/116166-how-do-you-tell-what.html
You should get the Idea... Tag-stamps numbers are good if someone has not changed the gears out at some time.
PostPosted: Wed Jun 11, 2008 7:02 am
Oh if it is a stock luv. Most were 4:11, the automatic came with a 3:73 or something like that
Other guys will know for sure.
Do not get a ratio that will not let the engine run at a rpm where their is enough power to pull the truck down. You could actually get worse fuel mileage.
PostPosted: Wed Jun 11, 2008 4:12 pm
o.k., yeah, thats what i need to know. Mine is an auto, so is anyone sure on the gearing for an auto?
PostPosted: Wed Jun 11, 2008 4:50 pm
Here you go.
It all depends on the year for what gears came in the LUV.
72-75 ALL: 4.56
76-78 ALL: 4.10
79-80 4sp and Auto: 3.73
81-82 4pd: 3.42
81-82 Auto: 4.10
79-82 4x4: 4.10
http://forums.luvtruck.com/viewtopic.php?f=6&t=11013&hilit=automatic+gear
PostPosted: Wed Jun 11, 2008 8:04 pm
Sounds like a swap with an 81-82 Luv with a 4 speed standard transmission's rear end would be the way to go. That should improve your gas mileage without bogging you down too much.
Now you just have to find one...lol
