It is currently Mon Jun 08, 2026 11:55 am
 Post subject: Carb help
PostPosted: Wed Feb 15, 2006 9:40 pm
Ok, you know when you press on the gas there's a little flap on the carb that opens up to let air in. Well on my truck that thing doesn't open and close with the gas. It was just staying wide open and it ran like crap so I wired it half way open for now. I figure it's something tiny like a spring or something but I have no idea where it connects to and things like that. So I'm looking for help, if it is a spring, do you guys know where it connects to. I have looked but I can't find a straight path for a spring or something....
2002 Lexus RX300
1998 Honda Accord
1977 Chevy Crew Cab Dually
1954 Ford F100
http://www.yvtruckclub.com/forum
 Post subject: flap
PostPosted: Wed Feb 15, 2006 10:12 pm
If it's the very top "flap", it's the choke and the spring is in a round "thingy" on the side of the carb near the top. The black cover comes off the round "thingy" & a coil spring is inside.
PostPosted: Wed Mar 01, 2006 5:35 pm
Sounds like a bad or out of adjustment choke thermostat to me.
PostPosted: Wed Mar 15, 2006 12:48 am
Check your cable on the manual choke. Choke may be pulled back if staying open. Check springs.
Check the control arm on electronic choke. could be missing pin to hold arm for choke.
PostPosted: Fri Mar 17, 2006 12:58 pm
Just the opposite happend to me, mine was stuck closed.
1983 Suzuki Gs550 Sportsman
1986 Full size Chevy P/U
1993 Volvo 850 GTL
Users browsing this forum: Google [Bot] and 18 guests
