 Post subject: No Power!!!!!!
PostPosted: Mon Feb 06, 2006 9:17 pm
Banishment Pending
Well I started up my truck this morning, and drove from Phx to Prescott, about 90mi uphill. it ran fine at idle, but when I stepped on it there was a serious lack of power, I' got a new fuel filter, haven't put it on yet but I'm hopping thats the problem, because I'm about 250mi from all of my tools :evil: any thoughts? ideas?
PostPosted: Tue Feb 07, 2006 2:23 am
could be a loose carb. I had this problem last time i pulled Snoqualami pass. It was poping and stuff realy bad. It got to the point where it wouldnt even run, tightened the carb dow and i havent had a problem.
PostPosted: Tue Feb 07, 2006 9:15 am
Banishment Pending
alright, I'll check that out today and see what I come up with.
PostPosted: Tue Feb 07, 2006 2:05 pm
Banishment Pending
well replaced the fuel filter, that helped a little, checked to see if the carb was all tightened up, it was, took it around for a drive and found that i didn't start to lose power until about 2500-3000 rpms, I'v pretty much narrowed it down to a carb problem, more than likely a clogged jet. So what I'v decided is to fork out the cash for a Weber and get it over with, I'm tired of screwing around with the Hitachi piece of crap.
PostPosted: Tue Feb 07, 2006 4:20 pm
yoiu might also try cleaning and regapping your points. Test the resistance of the coil, check the cap for cracks/corrosion.
PostPosted: Tue Feb 07, 2006 4:37 pm
Yeah it sounds like a points issue to me. Weak fuel pump and bad points can act a lot a like. Water in the gas also can act just about the same.
 Post subject: Low power
PostPosted: Tue Feb 07, 2006 6:52 pm
When my 80 luv did this I finally trached it down to a timming chain thae managed to jump about 2 teeth. I took sprocket loose and moved it about 2 teeth foward. This cured problem until I could get home and replace timming chain and componets. This happend between Las Vegas and Kingman.
1980 Luv 4X4
another 1980 luv 4x4
PostPosted: Tue Feb 07, 2006 10:15 pm
Banishment Pending
I'll check the points, and the cap, I don't think it's the gas, I've been getting Chevron so I don't think it's that. I could be the fuel pump, but i doubt it as it's only about a year and a half old. I'm also pretty sure it's not the timing chain, I redid the head in May, and I know it's all good. I'm still going to get the Weber though, I like the idea of a little more power.
