It is currently Mon Jun 08, 2026 7:59 am
 Post subject: carb help!!
PostPosted: Mon Nov 21, 2005 10:14 pm
I finally got my truck running with the 3.8. For some reason, it idles high. On the carb it has two vacuum line; one in the back and on the passenger side. For the brake, I connected the rear vacuum line to it and pledged the other off. There is also a vacuum line that goes to the tran, I connected it to the intake manifold. The adjustment screw is backed off so that's not the reason. I need help!
PostPosted: Mon Nov 21, 2005 10:22 pm
1st guess is a vac. leak. Get you a big can of carb cleaner, and start spraying around everything. Good luck :!:
Users browsing this forum: Baidu [Spider], Bing [Bot] and 32 guests
