It is currently Mon Jun 29, 2026 3:34 pm
 Post subject: Reverse light swich
PostPosted: Tue Oct 11, 2005 10:57 pm
1980 luv 4 speed . My reveres lights are out.
I think I have traced
.them to the switch on the trans.
Any help or ideas are welcomed.
Where is this part available.
Thanks
PostPosted: Wed Oct 12, 2005 12:17 am
When in reverse, do you have any power going to the light??Probably is the reverse switch.
PostPosted: Wed Oct 12, 2005 3:24 am
You can unplug both wires at the switch and hook them together. If your lights work then you know it can only be the switch that is bad. Should be on all the time that the key is on.
Reverse lights are commonly pretty corroded on LUVs. The gasket on the tailight starts leaking at the bottom first it seems, and the bulb sockets get pretty nasty. Bypass the switch, turn on the key, and then take the lense off the tail lights and wiggle/replace bulbs until it works. Turn off the ignition if you are going to clean the sockets with anything metal as that will avoid shorting something out.
PostPosted: Wed Oct 12, 2005 6:37 am
Everything that he said! ^
good call 800!
03Cobra
PostPosted: Fri Oct 14, 2005 3:56 pm
Thank you for the info.
Now, where can I buy a reverse switch?
PostPosted: Sat Oct 15, 2005 2:27 am
GM dealer maybe, Isuzu dealer maybe. try http://isuzu.stcharlesauto.com and see if they can find you one if your local GM dealer strikes out. St Charles has a very good parts department for finding tough to get parts, and they usually do free shipping.
Failing that, head to the junk yards. The switch off an Isuzu up to say 86 or so would be a fair bet to work as well as one off a LUV.
PostPosted: Sat Oct 29, 2005 10:29 am
or if you dont mind te element of unreliability you can get one from a junk yard
