It is currently Sun Jun 28, 2026 11:25 pm
 Post subject: rear u-joint
PostPosted: Sat Oct 01, 2005 9:01 pm
All righty fellers, help me out. my stocker is not in the moving mood.
I took the driveline out to replace the rear u-joint. My problem is I cannot get the damned caps to come out. I busted a couple of the clips but ended up getting them out. I can't get the caps to move at all. Any ideas?
BTW the one leg hogged out the cap so bad no more needle bearings 8O
Resident lurker
PostPosted: Sun Oct 02, 2005 1:55 pm
A big vise and a smaller socket usually gets them to move. It's best to have 2 people doing this, one to hold the drive shaft up and the other to squeeze the socket on to the cap of the u-joint. Once you get it moving, it should be easy after that.
PostPosted: Sun Oct 02, 2005 6:10 pm
Got them out, basically with the same method only no big vise, big hammer instead. socket on one side, drift pin on the other. scored up the yokes a bit, cause the open end of the caps were flared out. Lots a cussin, some light taps, cussin, not so light taps, smoke break. repeat with increased tap force as needed.
Moral of the story, if your u-joints start making noise, don't put off replacing them.
Resident lurker
PostPosted: Sun Oct 02, 2005 7:14 pm
Thought they were gonna be diffacult, should of called me!!!!
Users browsing this forum: Bing [Bot] and 48 guests
