It is currently Mon Jun 08, 2026 2:07 am
PostPosted: Thu Jun 02, 2005 11:25 pm
The bearing that supports the driveshaft, it looks toasted.Got the new part,checked my haynes book and it says to plug the hole that the driveshaft comes outta.My question,is it going to gush oil? Should I drain the tranny first?
Dr. Frankenstein
PostPosted: Thu Jun 02, 2005 11:34 pm
if you have the truck nose high, it'll leak a fair amount of tranny lube. I'd drain it and save the mess and put in fresh when you're done.
PostPosted: Thu Jun 02, 2005 11:36 pm
what about jacking up the back,will I still be able to get at it? my garage is a little slanted so I could probly get the angle kinda steep
Dr. Frankenstein
PostPosted: Fri Jun 03, 2005 12:06 am
as long as you blocked the front wheels real well, that should work just fine... shouldn't leak much then..
PostPosted: Fri Jun 03, 2005 12:13 am
thanks for the tip
Dr. Frankenstein
PostPosted: Fri Jun 03, 2005 12:16 am
no prob
PostPosted: Sun Jun 05, 2005 3:44 pm
had to walk to the hardware store for a socket big enough to get the companion flange off but I got .The old donut was so one sided! I think if I could have just replaced that it woulda been just as good. Got rid of my 4th gear noise,Hurray!Oh yeah the ramps under the back wheels w/my garages floor like it is worked fine,not a drop of oil.
Dr. Frankenstein
