It is currently Mon Jun 08, 2026 7:59 am
PostPosted: Wed Mar 30, 2005 5:58 pm
ben you know what im talking about
I had startup but after carb bowl emptied would die ok so what
i changed the fuel pump from the funky hitachi barrel loking thing to a inline veedub/ audi pump i got off ebay
works but smokes like and s.o.b. running real rich
carb has less than 100 miles after re-build
i dont know what year the carb is but is 2bbl hitatchi like most luvs
ran like hell when i got back from re-build but smokes now NOT oil NOT water is real rich
is there a mixture adj screw besides the one on the side that i just cant find? it is a cali model
i have blown heads and gaskets on this 167,000 +- original motor with out pucky like this
i have a small block to build for it but im gathering all the bits and peices to put it together right the first time
anybody have any ideas :?: or is there a different carb i can use?
i need this thing drivable to get inspected by state troopers and stupid smog check.
HELP!!!!!!! :cry: [/u][/i][/b]
PostPosted: Thu Mar 31, 2005 12:40 pm
Did it smoke like this before the other pump was put on? You could pull the wire to it now and check as well. It should run 30 seconds or more on what is in the bowl of the carb. What I'm thinking is that perhaps the pump you are using is putting out too much pressure and blowing fuel past the needle valve and into the carb.
You should also check that the fuel return line is clear and hooked up. That should help relieve quite a bit of excess pressure.
The mixture adjustment is right at the base of the carb, on the primary (outer) side. Most of the LUV carbs I've seen have it right out in the open, but later Isuzus I've worked on have it hidden behind a plug.
If its not the pump overpowering the carb, then my gut says the rebuild either didn't get done right or the carb still needs adjustment.
PostPosted: Sun May 01, 2005 11:04 am
Your problem is that you still have the stock Hitachi carb :D. You should look into getting a Weber
1983 Suzuki Gs550 Sportsman
1986 Full size Chevy P/U
1993 Volvo 850 GTL
PostPosted: Sun May 01, 2005 9:47 pm
He said he's in California and has to have it pass smog inspection. The Weber won't do that.
PostPosted: Mon May 02, 2005 1:35 am
my weber on my yota has passed everytime for the last couple years since I put it on, but then again I'm not in California
PostPosted: Sun May 15, 2005 5:13 pm
Usually all you have to do is find that funky round barrel Hittachi thing, remove the end, and replace the filter that pops out. Most of these pumps are discarded when there is nothing wrong but a plugged filter. When you go to the auto parts place and ask for one they will look at you funny and say there isn't one. Just ask for one for a Datsun 240Z. Same thing.
Yes, your replacement pump will not work. Probably one from a fuel injected car. Luv operates on 3-5 PSI.
 Post subject: Runnin Rich
PostPosted: Sun May 15, 2005 11:26 pm
Be real careful... if that pump is off VW/Audi then there a real good chance its for a Fuel Injected motor, in which case the pressure that thing pumps out has got to be enourmous. Be sure to confirm the fuel pressure.
What you want to look for is either a faucet or rotary style pump... like he said above- putting out 3-5lbs.
I just picked up a CB Performance rotary style pump... they aren't cheap but they work real nice! http://www.cbperformance.com/default.asp
Faucet pumps are ok.... just not as reliable as rotary- they also make a real cheesy soundin noise.
Users browsing this forum: Baidu [Spider], Bing [Bot] and 32 guests
