It is currently Mon Jun 08, 2026 2:08 am
PostPosted: Wed Apr 27, 2005 8:54 pm
I believe I need to have the Carb. rebuilt in the 1980 Luv. Where is the best place to purchase from (website etc.)???? How much you think it will cost to have it done??
 Post subject: rebuild
PostPosted: Wed Apr 27, 2005 10:23 pm
For a Hitachi or Weber. The Hitashit isn't worth pouring a bunch of money into. The grief just returns. Most everyone here will advise buying a Weber.
PostPosted: Wed Apr 27, 2005 10:26 pm
I rebuilt the the PileOShity carb twice and never got it runnin right. Spend the extra cash and get the Weber. The truck will thank you.
`79 LUV 2WD Stocky
`80 LUV 4WD Stocky
 Post subject: Weber???
PostPosted: Thu Apr 28, 2005 12:22 pm
Where can I get the best deal on a weber?
 Post subject: Another ?
PostPosted: Thu Apr 28, 2005 12:28 pm
"Weber 32/36 DGAV Progressive Dual Barrel" ..... I found a used one of these will it work. Says Unit is jetted for a 2.0 L BMW E12 engine.
PostPosted: Thu Apr 28, 2005 3:31 pm
Swap Specialist Mod
that will work great on your truck. do you have any adapter plate? i bet someone on here could help ya out with one of em.
neil
 Post subject: weber
PostPosted: Thu Apr 28, 2005 5:24 pm
http://www.webercarbsdirect.com/?source=googleadwords
http://www.webercarburetors.com/
http://www.redlineweber.com/SEMA2002/ht ... ilters.htm
 Post subject: Uggggg....
PostPosted: Thu Apr 28, 2005 5:49 pm
Uggggg...I'm not sure what I need? So that will work? What is the difference between DGV, DGAV, DGEV,...what adapter plate do I need? Wow..so many questions....sorry :(
PostPosted: Thu Apr 28, 2005 7:44 pm
I bought my from JT Speed out of NC. Cant remmeber the price, came with everything to bolt on and drive.
DGV Manual Choke
DGEV Electric Choke <---- the one I got
not sure about DGAV
`79 LUV 2WD Stocky
`80 LUV 4WD Stocky
PostPosted: Thu Apr 28, 2005 8:11 pm
Swap Specialist Mod
i think the DGEV is the 38/38 outlaw carb. i think theyre made so both barrles open at the same time.
neil
PostPosted: Thu Apr 28, 2005 9:23 pm
DGV is manual choke DGAV is hot air choke and DGEV is electric choke. The one to look for is the 32/36 DGEV. Thats what most people run and its a been a great carb to me.
PostPosted: Thu Apr 28, 2005 10:48 pm
The kit # is Weber K662 for the 32/36, or K662-38 for the 38/38. Either will work, but good luck finding a 32/36 kit new, I was looking last week and every place I contacted didn't have them and wouldn't for an unknown amount of time. Apparently due to the popularity of that kit and the fact there was or currently is a strike going on at Weber, that and something about them moving their facilities, there is a mass shortage.
Anyway the bottom line is you are probably only going to find a used one somewhere (32/36), then have to find the adapter and other misc parts, along with a rebuild kit. There are plenty of the 38 kits available, they are a little more expensive, but will work equally as well, at least based on the information I have been able to find.
I tried to rebuild my stock Hitachi, with miserable results, then ended up buying a rebuilt one off of ebay. That one ran great for about a month and now has taken a dump, which is why my quest began for the Weber.
Another option is to buy a reman Hitachi, but based on the pricing I found for those, you are looking at half the cost of the Weber and will still have the same POS you just got rid of. But if you are interested I can post up the links I found for those.
Good luck and I hope you find what you need.
Chad
PostPosted: Fri Apr 29, 2005 5:27 pm
The difference between the DGAV that you have and the DGEV is only the choke. It's always warm in North Carolina, so who cares about the choke, right?
The adapter plate is $21.50 new from Weber, P/N 100.099
Here's the link:
http://www.webercarbsdirect.com/inc/pdetail?v=1&pid=912
You went there in that?!?!
