It is currently Mon Jun 08, 2026 1:00 am
 Post subject: Tach
PostPosted: Tue Aug 31, 2004 10:25 am
Does anyone know how i would go about installing an aftermarket tach in a Luv?
PostPosted: Tue Aug 31, 2004 11:46 am
OG Lifer
If you have the instructions, follow them and make sure the tach can be used with a 4 cylinder. I am not sure about stock engines, but on a sbc, there is a place on the distributor (a pin on the ignition control module) to hook up the tach signal wire.
WATCH YOUR PIEHOLE!!!!!!
PostPosted: Tue Aug 31, 2004 12:07 pm
hey thanks for the help. i found a good article online for anyone else who would like to know.
http://www.fourwheeler.com/techarticles/71078/
PostPosted: Mon Dec 20, 2004 12:49 pm
i got a tachometer for my truck, havent finished wiring it yet though, heres some pics.
PostPosted: Wed Dec 22, 2004 8:16 pm
thats exactly where i had mine mounted. But now i have a shiney new Auto Meter tach on my dash.
PostPosted: Wed Dec 22, 2004 9:52 pm
Can you put one on a diesel and does anybody know how????
PostPosted: Wed Dec 22, 2004 9:53 pm
lol.. seems to be the only real good place to mount it.. got mine ther too
PostPosted: Thu Dec 23, 2004 4:51 am
i know you could go mechanical whith it, but that would be alot of labor there. I would think you could mount it up off the injectors instead of the coil. I would think the injectors would fire like spark plugs fire on a gaser. Or i could be completly wrong and making an ass of myself... :lol:
PostPosted: Thu Dec 23, 2004 4:56 am
No....No....Say it ain't so!! :smt102
77 2wd - Back on the road
05 Ford Five Hundred
PostPosted: Fri Dec 24, 2004 4:49 pm
the only problem with hooking it up to the injector is cause not all injectors fire in sequential order like spark plugs. some engines fire injectors at the same time but if they do fire sequentialy you could probaly theareticaly do it. but i don't know to much about the deisels. matt
PostPosted: Sun Dec 26, 2004 1:20 pm
inectors on diesels are not electronic, they work off pressure in the pump they have, but you can put a tach. on a diesel, you just need the right type of plug that goes into the side of the pump... it looks like a bolt w/ wires comin out of it, prob. is that you'd have to take the pump off and out to get to it... but finding a tach. that plugs into the pump is another story, i've yet to see those 2 parts EVER... but chiltin's shows the plug in their book....
