It is currently Sun Jun 07, 2026 6:43 pm
 Post subject: Power Brake Booster
PostPosted: Tue Jul 27, 2004 3:19 pm
Can anyone give me a link or a phone number where I can get a Power brake booster? I will send mine for rebuilding if necessary, but I just don't know who to call. The local Parts Plus wants $120.00 to ship one from Pennsylvania (I'm in Georgia). I think that's a little too expensive....
Is it???
Ed
autoed@bellsouth.net
 Post subject: Booster
PostPosted: Fri Aug 06, 2004 4:08 pm
How do you know the booster is bad? I just replaced the master cylincer
on my luv and was wondering what the boosters go for.
I priced one here in CA and I like it was about 110 at a local auto supply
Try JC Whitney.
http://www.carparts.com
PostPosted: Fri Aug 06, 2004 4:48 pm
I know mine's bad because the brake pedal is hard, and the stupid thing whistles at every stop light... driving me crazy!!!
 Post subject: Power brake booster
PostPosted: Fri Aug 06, 2004 6:59 pm
hi autoed , before you replace your power brake booster, check the hose first , the one that is going to the diaphragm and the plastic fitting ...mine was cracked and was doing the same thing ...i replaced them both and it works great now,, hope this helps out... may save you 100 bucks,,,,Matt
PostPosted: Fri Aug 06, 2004 8:07 pm
Guys guys....help has arrived 8) Ive got about 50 brake boosters in stock (USED) MUCH cheaper than $120.....pm me for price and details :wink: :D
 Post subject: 50?
PostPosted: Sat Aug 07, 2004 12:37 pm
50!? Do you own a wrecking yard?
PostPosted: Sat Aug 07, 2004 3:44 pm
He doesn't have a wrecking yard, he has a luv yard :lol:
PostPosted: Sat Aug 07, 2004 8:13 pm
Thank you luv355 :D
PostPosted: Sat Aug 07, 2004 9:57 pm
there is a test to verify for sure that the booser is bad. with the truck not running, push down on the brake pedal till it starts to get hard. now start the truck up and the brake pedal should move down an inch or two. if it doesn't move at all then the booster is bad. i've only seen one bad booster and that was on a 76 chevy, and you literally had to stand up on the brake pedal to stop the truck. my luv has a hard pedal but the booster works and it stops good.
1980 chevy luv 4x4 1.8 liter
1979 luv long bed parts truck
Users browsing this forum: Baidu [Spider] and 56 guests
