It is currently Sun Jun 07, 2026 8:15 pm
 Post subject: Tacho
PostPosted: Sun Jan 25, 2004 1:26 am
This probably sounds really stupid but i dont know how to put a tacho on the stock engine or even know if you can. Can someone help? I want a tacho but dont know how...not really a mechanic...
PostPosted: Sun Jan 25, 2004 2:45 am
i wana do the same thing with my luv, im not to sure myself but i have friends that know, there guna help me. ill try n get some info if i can
PostPosted: Sun Jan 25, 2004 2:53 am
well i screwed up a tach on my luv by barely reading instructions i hooked the wire that supposed to go to the coil but put on the resistor :oops: i didnt know i just looked at the picture barely thought it was where it went boy it fried the tack it went backwards kinda funny lol so dont hook up to white resistor on top of coil and also for hooking up the light on one be careful where you connect too i blew out a couple fuses :oops: get a test light and check they come in hand
their is only 4 wires at least on mine
I believe it is white one for ground, black to coil, green one for light at night and red for constant power
but just read the instructions if you have any
hope this helped
PostPosted: Sun Jan 25, 2004 6:45 am
A tach is usually 4 wires and they aren't too complicated. Sunpro tachs are set up like the following, and I assume most others will be similar:
Red: constant +12 volts with key on
Black: ground
Blue or White: Connect to dash lights for the guage backlighting
Green: Tach signal from electronic ignition, or connect to negative side of the coil on older cars (like stock LUVs)
You'll also usually have some kind of setting for 4, 6, or 8 cylinders to set on the tach. Like jk said, read the instructions or look at the tach for a wiring diagram.
PostPosted: Sun Jan 25, 2004 9:55 am
OG Lifer
Just read, re-read, and then read the instructions again. I hate it when people start chopping wires and just hooking stuff up till it works. It makes it that much harder for the next guy.
WATCH YOUR PIEHOLE!!!!!!
PostPosted: Sun Jan 25, 2004 12:00 pm
tachs come whith perty good directions. Just follow them and your good. Just be shure to refrense the directions offten to make shure your doing it right.
PostPosted: Sun Jan 25, 2004 2:50 pm
wow...didnt realize was so easy. I just didnt understand how the tach got the rpms but apparently it getsem from the coil?
PostPosted: Sun Jan 25, 2004 7:18 pm
i know wat grimace is talking about, i have wiring everywhere!
you know on the gauges, how one is for speed, and the other is for temp and fuel etc, i want to put a tacho in the second one and have little gauges for fuel and temp, can ya get a tacho made to fit?
