It is currently Sun Jun 07, 2026 8:16 pm
PostPosted: Wed Dec 31, 2003 11:25 pm
anybody know what the gaps should be on vavle intake and exhaust valves cold and hot on '79 chevy luv 4x4 stock engine?
PostPosted: Thu Jan 01, 2004 1:20 pm
I think it is this.
In. 0.006 (0.15MM)
Exh. 0.010 in(0.25MM)
Hope that helps. This is on an 1980 model
PostPosted: Thu Jan 01, 2004 2:01 pm
OG Lifer
Should be the same on 79 and 80.
WATCH YOUR PIEHOLE!!!!!!
PostPosted: Thu Jan 01, 2004 2:33 pm
is this when it is hot or when it is cold? The reaon i even ask is because i want to check them....simply because the engine was rebuilt recently by someone i dont know. The guy i bought the truck from either rebuilt it himself or had it rebuilt.....he had it bored out by a local machine shop to so all cylinders have about 180lb psi :D Neways, when im driving it...it accelerates great sounds awesome...until i let off on the gas and leave in in gear. It pops and backfires and makes all kinds of nasty sounds unless i take it out of gear and then it idles right down. Any ideas wut it could be? I have heard that possibly poor valve job, but what else could i try?
PostPosted: Thu Jan 01, 2004 3:36 pm
OG Lifer
According to the series 9 manual, these measurements need to be taken cold. It says "low temperature". The backfiring and popping could be distributor timing, or carb problems. There is an anti-dieseling solenoid and a coasting richer solenoid. Both of these are related to in-gear deceleration. I had multiple problems with my stock hitatchi carb, and replaced it with a weber 32/36 dgev electric choke carb from carbs unlimited. The kit was about 325.00 and came with everything I needed to switch from stock to weber. Hope this helps.
PostPosted: Fri Jan 02, 2004 1:02 am
oh...i forgot to mention. When the guy rebuilt the engine he removed ALL emmisions stuff and a lot of electrical stuff appears to be gone. LOL... could that be part of it???
PostPosted: Fri Jan 02, 2004 8:10 am
OG Lifer
That could be part of it. Have you done any research to see what all is gone?
PostPosted: Fri Jan 02, 2004 2:50 pm
dont know how to figure out what should all be there....from what i can tell i can see there must have been some kind of air pump on the thing thats completely gone....there is only one hose connected to the carb and that one is one i connected to it from the original air cleaner i found and installed. All holes i can see are plugged but who knows I could have missed some. Im going to fix that soon with 32/36 carb. It runs so poorly with that carb i dont know why they bothered with it...might have better luck spraying gas straight down the frkin manifold with a spray bottle.....as far as electrical missing i have no clue wut the truck came stock with. I imagine a manual for the truck might help me with that, anybody know where i can get an orginal shop manual?
PostPosted: Fri Jan 02, 2004 11:28 pm
OG Lifer
Ebay bro. That is a lifesaver for hard to find parts.
PostPosted: Fri Jan 09, 2004 7:10 am
Last time I looked, there was one up there that expires tommorrow. Will check now...
http://cgi.ebay.com/ebaymotors/ws/eBayI ... 2452457167
These are for a 8 banger conversion though. I think the other ended.
Users browsing this forum: Baidu [Spider] and 43 guests
