It is currently Sun Jun 07, 2026 9:43 am
 Post subject: 79 80 4x4 Tranny Same?
PostPosted: Mon Dec 29, 2003 1:39 am
I just need to know would a 1980 4x4 luv tranny fit in a 79 4x4 luv? Also, wondering if theres a five speed somewhere that would fit the stock 1.8l engine? I think this may have been covered in previous post somewhere? Anybody know?
PostPosted: Mon Dec 29, 2003 7:44 am
They are the same.
PostPosted: Mon Dec 29, 2003 2:48 pm
five speed out of an early Trooper.
Resident lurker
PostPosted: Mon Dec 29, 2003 4:19 pm
well contrary to popular beiliefe i dont think that the isuzu 5speed will fit the 1.8L. The MUA 5 has a completely diferent bolt patern, this is one big reason why you dont see 5speed 1.8L and 1.9L troopers. There might be an adapter out there somewhere though. As far as LUV trannies, 78-80 should be the same. Good luck :D
 Post subject: not the same
PostPosted: Mon Dec 29, 2003 5:24 pm
actually there is a little bit of differance, i did a swap earlier this year the 80 motor and tranny fit in alittle bit different on a 79 and vice versa, the 80 driveline wont fit into the 79 tranny but the 79 driveline will fit into the 80........................this is just what i went through when i swapped mine!!!!!!!!!!!!!!!
PostPosted: Mon Dec 29, 2003 6:26 pm
is it the slip yoke spline count? Becouse i know my 80 has about a 24spline slip yoke and my 78 had a 17 or something around there.
PostPosted: Tue Dec 30, 2003 9:16 am
Hummm....I thought we were talking about 4x4... A 78??
PostPosted: Tue Dec 30, 2003 6:02 pm
all 2wd that i have seen have had larger splines ao there is less sso that why the 78 had about 17 or so matt
PostPosted: Wed Dec 31, 2003 8:13 pm
Search for my other posts...I don't remember the tranny number right now but the right 4x4 5spd tranny from a trooper will bolt directly to the LUV motor.
I have the tranny in my garage and am getting ready to cut my frame to make room for the extra length.
PostPosted: Wed Dec 31, 2003 11:13 pm
oh....lol....you have to modify the frame? I thot it would bolt up to the same spot as the 4speed? Guess not...
PostPosted: Thu Jan 01, 2004 4:04 am
hummm thats odd. I had heard (when i asked a simmilar question on another board) that the 5speed 4x4 tranny out of a trooper (Isuzu MUA5) would not bolt up to the 1.8L motors. I might have to investigate this when i have my trooper tore down... :?
PostPosted: Sun Jan 18, 2004 10:31 pm
Not the MUA5....it's the MSG-5ET that bolt to the block. But it is 4" or so longer than the 4-spd LUV tranny.
PostPosted: Sun Jan 18, 2004 11:16 pm
I've been working on getting this one figured out. My working theory is that the motor switch (to 2.6L FI) in mid-87 troopers included a trans switch as well. The only monkey wrench in that theory is the fairly large number of 2.6L to 2.3L block swaps I've heard of with no mention of problems mating to the trans that shipped behind the 2.6L.
The couple of pictures I've seen on the 88+ trans (aka MSG-5F, I think MUA5 is a family name shared by both) it looks like the starter is on the let (from seat) side of the motor. That might be part of the problem right there.
General feeling right now is go for an 84-86 trooper five speed for the best chance of it fitting.
Users browsing this forum: Bing [Bot] and 22 guests
