 Post subject: Overheating problems
PostPosted: Sun Dec 14, 2003 8:10 pm
My luv has a problem overheating. I replaced the thermostat and if I am sitting in one place for about 15 mins it gets hot. Its not a radiator problem, my is fairly new. So I am thinking of putting a flex fan in place of the stock fan and then mounting on the outside of the radiator a electric fan with a toggle switch in the cab.
Has anybody esle done this or something similar?
PostPosted: Sun Dec 14, 2003 10:12 pm
are you maybe losing coolant thats what happend to me i bought a new radiator and stuff which it needed but still overheat it was losing coolant through the blown head gasket :evil:
PostPosted: Mon Dec 15, 2003 12:00 am
make you a fan shroud.i made 1 out of some thick plastic.now i run alot cooler.
PostPosted: Mon Dec 15, 2003 1:05 am
Ifg you dont have a shroud air wont flow right. Also somethi ng i would do is hose down the radiator to make shure its clean, watch coolant level, and presure test the system and the cap.
PostPosted: Mon Dec 15, 2003 9:30 pm
Can you give me some more info on how you belt your shroud? I am not familar with modinf plastic myself. (your post kinda reminds me of yoda)
"A fan shroud you need, make your engine run cooler...yes hehehe")
PostPosted: Mon Dec 15, 2003 9:36 pm
LOL :lol: :lol: :lol:
I would check you local wrecking yards. If you have a pull it yourself yard around a shrowd should be cheap, provided you can find a luv. :?
PostPosted: Tue Dec 16, 2003 7:42 am
What does the water pump look like? Rusted and leaky or sound?
PostPosted: Tue Dec 16, 2003 10:37 am
i used a piece of about 1/8 thick plastic and cut it about 4in wide and about 3ft long.and just curved it around the fan were i wanted it then used some L brackets and mounted them to the rad.supports.it does a great job.my temp runs about 3 hands cooler on the gauge than used to.thats about the best i can say it.it was just a brain storm i had and it worked lol.you could cut a strip from a plastic barrel and should work also.
PostPosted: Tue Dec 16, 2003 11:31 am
make sure you aren't loosing fluid through the head.
you might have a blown head gasket or cracked head.
unfortunately it is a common problem with the isuzu engine.
03Cobra
oh yeah if you don't have a shroud and need one I will look to see if I still have one laying around.
03Cobra
 Post subject: fan shroud
PostPosted: Tue Dec 16, 2003 10:32 pm
That would be greatly appreciated. I was going to go Saturday to the wrecking yard, but if you have one that you think will fit. I'd buy it off you.
thanks
PostPosted: Wed Dec 17, 2003 5:54 am
ok I will write me a note and look tonight....(if I don't have a note I forget)
I will let you know tomorrow
03Cobra
PostPosted: Thu Dec 18, 2003 4:51 pm
I checkd for leaks, didtn see any. Now I think I have a hose off somewhere, it doesnt want to idle. (have 2 fairly new fule filters and new
air filter) but I also have the thermostat out, was testing to see if it got hot without the thermostat. :?:
PostPosted: Fri Dec 19, 2003 1:23 am
Izusu should have put a shroud on the LUV's. As far as I know, they never did. Maybe the LUV's with AC had a shroud?
PostPosted: Fri Dec 19, 2003 1:55 am
My 77 with Auto trans came with one, and most of the 79 and newer trucks I've gotten have them. I think they just started adding them to everything in about 79, and it was hit or miss before then.
PostPosted: Fri Dec 19, 2003 7:37 am
OG Lifer
My 79 has one. Not sure if it is the year or the fact that I have a/c.
WATCH YOUR PIEHOLE!!!!!!
PostPosted: Fri Dec 19, 2003 10:13 am
My 77 has one and it's a standard. But I'm not sure it may have been installed later.
PostPosted: Fri Dec 19, 2003 10:59 am
76 with auto and no ac has one. Never really paid attention before my 80 I think had one when the 4cyl was in it.
Resident lurker
 Post subject: shroud
PostPosted: Sat Dec 20, 2003 8:54 pm
Hey let me know about that shroud asap. Though for now cooling is better. I flushed out the system and I think before I had very little anitfreeze, so now i have a 50/50 ratio and it seesm to to the trick.
However I think a shroud would be good if I were stuck in traffic.
PostPosted: Sun Dec 21, 2003 10:43 am
hey to get by run your truck with the radiator cap loose meaning dont tighten it all the way and it will stay on thats what i had to do it will make it a lil better except startin in the cold well hope that works for you for a while
