 Post subject: still not idling
PostPosted: Fri Dec 12, 2003 6:46 pm
Just to let you guys know I rebuilt the carb and it still doesnt want to idle :( , I think that I'm just going to try and get a weber carb for it, a friend that works at midas said that he can get it smogged for 50.00 bucks, so thanks for all the help.
PostPosted: Fri Dec 12, 2003 6:55 pm
http://cgi.ebay.com/ws/eBayISAPI.dll?Vi ... 2447547207
go with this man. it's cheap for now. a weber will run you close to 200 bucks if you buy a new one :(
i was going to bid on it but chenged my mind
PostPosted: Fri Dec 12, 2003 7:31 pm
Do you think that this one will work it has a different cable linkage than mine, mine is kinda round
PostPosted: Sat Dec 13, 2003 7:08 am
thats why i'm not sure.
maybe someone can help??
mepr, you have a weber don't you ?
PostPosted: Sat Dec 13, 2003 12:56 pm
Yes i am running a webber. The throtle linkage looks the same as mine. What i had to do is modify things a bit. Youll have to get a wierd rottating nut thing that clamps the throtle cable in, after you get one of those juts grind the T off the end of the cable and your good to go.
PostPosted: Sat Dec 13, 2003 2:26 pm
What about this one and just rebuild it it has the same linkage, would I need to get an adapter plate for this one.
http://cgi.ebay.com/ws/eBayISAPI.dll?Vi ... 2447529466
PostPosted: Sat Dec 13, 2003 5:02 pm
Yes you'd need the adapter. Pretty sure the adapters are @ $40 but depending on how much the carb goes for and what needs to be done to it, could be worth it. BTW I have purchased from the this guy (ranchocortina). Seemed to be a good guy...
Dennis
Resident lurker
PostPosted: Sun Dec 14, 2003 9:22 pm
OG Lifer
I built my own throttle cable holder, and used the original arm assembly off of the hitatchi. It turned out real nice and operates wonderfully. I kept having a problem breaking my throttle cable with the stock weber set up. Will post picks if anyone wants them.
WATCH YOUR PIEHOLE!!!!!!
PostPosted: Tue Dec 16, 2003 7:48 am
http://cgi.ebay.com/ebaymotors/ws/eBayI ... gory=33550
How about something like this for a 73?
PostPosted: Tue Dec 16, 2003 7:55 am
Do the 4 Bangers in the Troopers or the P'ups have similar carbs? If so what years?
PostPosted: Tue Dec 16, 2003 8:14 am
http://cgi.ebay.com/ebaymotors/ws/eBayI ... 2448894705
this will work nicely :D
PostPosted: Tue Dec 16, 2003 5:05 pm
Troopers and PUPs are similar up to 85. In 86 the 2.3L came out and the mounting studs for the carb are different. The PUP may have been available with the 1.9/2.0L motor for a while longer than the Trooper, so 86 or 87 Pups might be worth looking at.
I don't know what kind of changes happened to the insides of the carbs on 82+ models though. You might find different emissions bits and pieces and maybe a little different jetting, especially on the newest models of the group.
PostPosted: Tue Dec 16, 2003 5:46 pm
I think the difference might be the addition of a catalitic converter on most models versus just the california models. You think?
PostPosted: Tue Dec 16, 2003 6:10 pm
I remember reading something about coasting richer valves on some vs slow cut solenoids on others. I forget exactly what the differences were though and what they would affect. You are right though in that some models in the LUVs had cats(cali emissions vs federal), but somewhere in the early 80s all isuzu models got them.
PostPosted: Tue Dec 16, 2003 6:48 pm
Do you remember if they were tied in with the air injector or the exaust manifold or stand alone (inline). I have a V-6 van and they are all inline with no vac or air injection.
PostPosted: Fri Jan 02, 2004 1:32 pm
Reason I ask is some Cat's tie back into the carb, while others tie into the air pumps. and the difference is I guess how much crap it pumps back into the engine.
