It is currently Sun Jun 07, 2026 3:37 pm
 Post subject: Problem with my 79
PostPosted: Tue Nov 25, 2003 5:46 pm
Lights go bright and then dim then bright several times within a minute...what is the deal....voltage regulator? Please help 8O
PostPosted: Tue Nov 25, 2003 5:53 pm
do you have a stereo ? or something else in your truck that might drain energy ?Is your battery any good ? is your alternater good ?
Well those are just some things i can think of off the top of my head ...
PostPosted: Tue Nov 25, 2003 6:01 pm
It does it when the sterio is off.....but I will have to check on the battery and alternator...thanks for the help.
PostPosted: Tue Nov 25, 2003 6:26 pm
it would most likely be your alternator.
Currently no more luv's... But in search of one!
PostPosted: Tue Nov 25, 2003 8:01 pm
see if they do it whith the motor not running. Something like this is either voltage regulator or alternator. But if the regulator is going heywire i would think you would have fuses blowing. Well pull the alt and take it to a parts store to have it tested, most will do this for free. If it checks out then its your voltage regulator.
PostPosted: Tue Nov 25, 2003 10:44 pm
start your truck then disconnect the battery cable.if it dies or acts silly its the alternator.
PostPosted: Wed Nov 26, 2003 7:14 am
My 79 was doing the same thing a few years ago....i unhooked the small black wire on my alt. , and it stoped doing it....still runnen' good!
PostPosted: Wed Nov 26, 2003 8:03 am
^^^ Thats what i did!!^^^ It ran good after that....till i broke the engine.... :roll: :lol:
PostPosted: Wed Nov 26, 2003 8:04 am
PostPosted: Wed Nov 26, 2003 12:56 pm
Pulled the battery cable off while it was running and it did not act funny at all...will check if it does it with the engine off..... :x
Users browsing this forum: Bing [Bot] and 27 guests
