It is currently Wed Jul 01, 2026 5:00 am
 Post subject: Heat Problems HELP!!
PostPosted: Wed Oct 01, 2003 7:35 pm
ok so I have no heat and I really want it can any help me out with some ideas or fix-its. I don't need a thermstat because I just got one. so plz help me out guys.
PostPosted: Wed Oct 01, 2003 9:51 pm
well check your coolant level, if thats down then youll have no heater but you motor will be running hot too.
PostPosted: Thu Oct 02, 2003 4:50 am
your valve for the heater core might be stuck closed.
it is to the left of the brake booster if you are looking at the firewall.
you might want to check that also.
03Cobra
PostPosted: Thu Oct 02, 2003 6:03 am
When i first got my luv. I went a whole winter without heat...then got to looking and found a valve right where luv4me said .. Where were you and your advice when i was freezen my ass off ??....I know, i know...you were staying warm.!
 Post subject: ohh yea
PostPosted: Thu Oct 02, 2003 5:02 pm
also my temp gauge dosen't work at all. and my value is open and i flushed my heater core.
PostPosted: Fri Oct 03, 2003 6:37 am
Your temp guage is a wire that leads to the passenger side of your engine block. When you put a new thermostat in it ..did you put the spring side up or down? Spring side goes towards your engine...down.
PostPosted: Fri Oct 03, 2003 7:41 am
hmmmm......do you have like 12 radiators? cause that would cause it not to heat up.....LOL
have you pulled the heater line off of the valve and started the engine to see if you have flow through the heater core?
does the truck heat up after a long time? might be a thermostat stuck open....
03Cobra
oh and LMAO john....yeah I was prolly warm....hehe
03Cobra
PostPosted: Sat Oct 04, 2003 8:38 pm
me personally i would take the opertunity to install an after market temp gage. They are alittle better becouse the old ones tend to get off from time to time and a temp gage that has numbers will tell you more.
PostPosted: Tue Oct 07, 2003 6:05 pm
do you guys know where to get a after market temp gauge that would fit in stock position or somewhere close to stock position and still look good.
 Post subject: no heat
PostPosted: Tue Nov 11, 2003 11:18 pm
Try bypassing the heater valve on the firewall. It is located right by the master cylinder. Every luv I have I had to do this to since I am in ND i dont need just a little heat I need all that I can get.
PostPosted: Sat Nov 22, 2003 9:35 pm
well i lost my heat 1 time and it was because..........where the heater valve is on the firewall on driverside.the cable comes out and connects to the cut off.their is a flat strip of metal "clip" that holds the cable still when you are switching it from inside the cab.the clip had come off mine and wasnt letting the valve open all the way.maybe this will help tried to explain best way i could.
