It is currently Sun Jun 07, 2026 3:49 am
 Post subject: tune up
PostPosted: Thu Apr 17, 2014 7:38 pm
I'm doing it up on my 74 lUv iv changed the cap and rotor but I'm trying to figure out were the wires go I can't find a diagram 8O
I can use some help thanks.
 Post subject: Re: tune up
PostPosted: Thu Apr 17, 2014 8:03 pm
Firing order is 1342. Did you remove the old wires without knowing where they went?
PostPosted: Thu Apr 17, 2014 8:29 pm
stupidly yes I did Im callin myself that. I cant post a pic.
PostPosted: Thu Apr 17, 2014 9:09 pm
I just looked at my manuals and they don't have a good picture of it. Best I can say is to start from square 1. Pull #1 spark plug, turn engine until there is compression there, remove the distributor cap and put number 1 wire to where the rotor points. I think the distributor turns counter clockwise, confirm by watching as you crank it. After #1 is found then just wire them up with the firing order.
PostPosted: Fri Apr 18, 2014 12:28 am
My book shows---While looking straight down at it over the passenger fender, #1 is in the 5 o-clock position #3 is the 2 0-clock position #4 is the 11 o-clock position and #2 in the 7 o-clock position. Of course this is if nobody has messed with or changed it before. Yes, it turns to the left.
PostPosted: Fri Apr 18, 2014 6:15 am
This might sound dumb but is cylinder 1 Closer to the fire wall or the radiator.
PostPosted: Fri Apr 18, 2014 6:21 am
This how i looked like b4 i started to change them
PostPosted: Fri Apr 18, 2014 11:09 am
That looks correct, 1342 going counter clockwise. Number 1 is closest to the front.
PostPosted: Fri Apr 18, 2014 11:20 am
So from the front it does 1,2,3,4 ??
PostPosted: Fri Apr 18, 2014 11:35 am
yep straight and simple
PostPosted: Fri Apr 18, 2014 11:39 am
I don't understand the confusion - you've got a photo showing how it went.
PostPosted: Fri Apr 18, 2014 11:48 am
I didnt know where cylinder number 1 was :lol:
PostPosted: Fri Apr 18, 2014 12:28 pm
Now you know.
PostPosted: Fri Apr 18, 2014 12:56 pm
Yup from front to back 1,2,3,4 thanks Guys.
PostPosted: Fri Apr 18, 2014 2:11 pm
Save the picture and help out the next guy. It will come up again.
PostPosted: Fri Apr 18, 2014 3:11 pm
Yup ill do that.
Users browsing this forum: Baidu [Spider] and 33 guests
