It is currently Sun Jun 07, 2026 7:32 pm
PostPosted: Thu Jul 18, 2013 9:58 pm
So i was trying to sell my truck, because my mom loaned me 900 bucks to buy a nissan 720, and the nissan was a smokin deal, but that was a week ago and my mom needs that money back so i think im gonna sell the nissan for about 1500, pay her back 1k than fix the luv with the leftover money, BUT i have very little experiance working on trucks, i love doing it but im only 16 so i havent had a chance to learn much, but is there any LUV owners near Vancouver who have installed the weber and would be willing to comeover and help a fellow luvver instal the weber? pizza on me for whoever can help me out with this.
'78 2wd LUV, Betsy, THE LUV MACHINE
PostPosted: Thu Jul 18, 2013 11:11 pm
or can someone atleast tell me what to do with all the vacuum lines and stuff?
PostPosted: Thu Jul 18, 2013 11:18 pm
Try looking at the info section at the home page of this site.
PostPosted: Thu Jul 18, 2013 11:50 pm
I tried, I try downloading the file and it will never open.
PostPosted: Thu Jul 18, 2013 11:57 pm
You are asking for help and don't even have the carb yet?
PostPosted: Fri Jul 19, 2013 12:01 am
I'm asking if someone would come help me instal it if I get it, is it wrong to start planning things ahead of time?? I didn't set a date and say "come to my house July 21st" so I don't see the big deal...
PostPosted: Fri Jul 19, 2013 10:08 am
if you were a little closer I would help ya. talk to love4theluv or skypanne, pretty sure they are in that area
I'm workin' on it
78 chassis with 75 cab
SBC
PostPosted: Fri Jul 19, 2013 10:11 am
Since you don't want to do your own research let me do it for you.
viewtopic.php?f=5&t=23292&p=177549&hilit=Installing+a+weber+carb#p177549
I am still willing to bet you will try to get someone to do this for you too.
PostPosted: Fri Jul 19, 2013 11:28 am
i can help you out, does you truck still have all the emissions junk on it?
PostPosted: Fri Jul 19, 2013 6:00 pm
Yeah it does have the emissions stuff
PostPosted: Sat Jul 20, 2013 12:46 am
yuck :lol: its gonna be interesting then lol I tore all mine off when I first built the motor, I think I still have my stock intake manifold that I plugged the egr port on, and the exhaust manifold is easy to put a plug in the egr port. the air pump and all that junk can be pulled pretty easy. if you want to keep some of the emissions stuff you probably can but the stock air cleaner will be gone so you cant vent the pcv into the air cleaner anymore... you don't want all that oily gunk going thru your new weber anyway.
PostPosted: Sat Jul 20, 2013 2:06 am
Should I start taking the emissions stuff off now than?
PostPosted: Sat Jul 20, 2013 8:28 am
I would get the weber first...
PostPosted: Sat Jul 20, 2013 9:22 am
You do know that many people have installed a weber with the emissions on.
PostPosted: Sat Jul 20, 2013 2:04 pm
Well if I can leave it on it take it off what do you recommend??
PostPosted: Sat Jul 20, 2013 3:49 pm
Depends, sounds like it just needs to run reliable. I would not reinvent the wheel.
PostPosted: Sat Jul 20, 2013 7:29 pm
So I should just leave things how they are and put the weber on?
PostPosted: Mon Jul 22, 2013 12:06 am
your truck is old enough that you don't have to have it, but it wont make a huge difference with or without it other than the time to remove it. the weber has a few vacuum ports you can hook the required lines to.
PostPosted: Thu Aug 01, 2013 3:19 pm
I'd help since I live right around the corner from ya, so if love4theluv isn't around or available, I'm down. As long as you get all the correct parts, we can research it and get it done. I'm no expert but I've managed to replace and fix problems on my truck with help from people on this site and it's still running strong. Just have to make sure it's done correctly.
I still need to get a weber for mine... ;-)
PostPosted: Thu Aug 01, 2013 11:04 pm
the vacuum diagram on the under side of the hood makes figuring it out really easy..
do you have the weber yet?
