It is currently Sun Jun 07, 2026 8:20 pm
PostPosted: Fri May 31, 2013 8:55 pm
I stupidly tried removing my window crank about 6 years ago, not realizing it has a retaining clip, and snapped splined shaft that's in the regulator. Well today was my "sort of" lucky day. Found a salvage yard with a window regulator for the driver side from a 78 luv for 35 bucks. The guy said he'd sell it to me for 20 because the splines are destroyed///non existent. Is there anything I can use other than pliers or vise grips? That will destroy it at some point. I'd like to get the handle back on there, and thought about using glue or something, but than it would be a PITA to remove if I ever needed to remove the handle again.
Any suggestions would be awesome.
Thanks!
PostPosted: Fri May 31, 2013 9:26 pm
I have seen some aftermarket cranks that use a set screw to hold the window crank on, I think they were for VW's and made by EMPI. I would hold out and see if you could find a good one from a member parting out a truck.
PostPosted: Fri May 31, 2013 9:34 pm
Luvrv8 wrote:
I have seen some aftermarket cranks that use a set screw to holt the window crank on, I think they were for VW's and made my EMPI. I would hold out and see if you could find a good one from a member parting out a truck.
So would I have to drill a hole in the splined shaft? That would be awesome if I could fix it just spending money on new window cranks.
And I don't think I want to remove that damn thing ever again. The window tar is a nightmare. ;-)
PostPosted: Fri May 31, 2013 9:50 pm
I said set screw.you don't drill holes for a set screw.
EDIT.
I found these, do your homework and see if the LUV shaft is the same size as the replacement.
http://www.ebay.com/bhp/aluminum-window-crank
PostPosted: Fri May 31, 2013 9:59 pm
EDIT.
My bad, I had no idea what a set screw was, :oops: didn't realize that I used them on my replacement shifter knob.. haha. Thank you for suggesting those, I'll do my homework and buy some. :ebiggrin
PostPosted: Fri May 31, 2013 10:14 pm
I might have a useable regulator for both doors, ill have to go look
I'm workin' on it
78 chassis with 75 cab
SBC
PostPosted: Sat Jun 01, 2013 12:20 am
That would be excellent! Let me know how that goes . I may have to possibly take one of them off your hands.
PostPosted: Sat Jun 01, 2013 2:40 pm
went and looked, passenger side is stripped but the driver side is good.
I'm workin' on it
SBC
PostPosted: Sat Jun 01, 2013 5:05 pm
How much to you want for it? Send me a pm if you're willing to part with it.
PostPosted: Mon Jun 17, 2013 2:58 am
if you can get them 1981-85 Mitsubishi mirage ( nz model name ) has very similar cranks , the fit is a bit tight though
