It is currently Wed Jun 10, 2026 2:41 am
 Post subject: Dome light
PostPosted: Mon Mar 25, 2013 7:46 pm
Hello All
Has anybody found a dome light that will work in a 1980 4X4, that will just replace the old one without cutting or drilling new holes.
as always thanks
 Post subject: Re: Dome light
PostPosted: Mon Mar 25, 2013 7:54 pm
I'm a complete zero when it comes to 1st-gen LUVs, but I have a P'up (= to a 2nd-gen LUV). I put a GEO/Suzuki dome light in mine and it's great. It mounts flat, so you don't have to cut out a recess to accommodate the socket. I used one existing mounting screw-hole, and drilled the other. The light came from a Metro, I think, but it was the same as the one in the Samurai and probably the early Tracker. It's brighter than my factory light was, too.
PostPosted: Mon Mar 25, 2013 8:28 pm
I used one from a Mitsubishi mighty max, I had to drill one hole in the plastic light base. I think the whole job took less then 15 minuets
PostPosted: Fri Mar 29, 2013 5:45 pm
I got one at the local auto parts store. Probably about $5 and better than stock.
PostPosted: Mon Apr 01, 2013 6:07 pm
I got one from O'Reilly's that fit without drilling new holes.
76 LUV
