 Post subject: parts truck driveshaft
PostPosted: Wed Oct 22, 2003 1:08 pm
i went to look at the 81 model 4x4 i talked about earlier and it had a 2 piece driveshaft. is that normal? its short wheel base. i need one for a 80 model but mine is 1 piece at least thats what was in the bed when i bought it.the length looks ok though..
thanks 804x4
A 1980 luv that chevy 4x4
PostPosted: Wed Oct 22, 2003 4:55 pm
mine is a 2 piece, but I have a 2wd longbed...
I TOOK UR MOM DRAGGIN LAST NIGHT
Bagged 84 Pup
Bagged 53 F100
stock 72 Citroen DS19
PostPosted: Fri Oct 24, 2003 6:30 am
A 4x4 with only one driveshaft??????
 Post subject: driveshaft
PostPosted: Fri Oct 24, 2003 11:14 am
i have one out of an '80, make a offer and pay for shipping!
PostPosted: Fri Oct 24, 2003 2:07 pm
the front driveshaft is in place but has a 2 piece rear driveshaft with a hanger bearing. mine is an 80 but has a 1 piece rear shaft, there is no crossmember with a hanger bearing is this normal for an 80 4x4.
thanks
PostPosted: Mon Oct 27, 2003 7:10 am
Yep , My 80 only has one rear driveshaft.
PostPosted: Mon Oct 27, 2003 3:48 pm
My 79 4x4, which is a lot like the 80 4x4's also has only one driveshaft in the rear. Correct me if I'm wrong here guys, but isn't the 81 LUV a whole different animal from the 80 anyway? Shouldn't he be out looking at a 79-80 LUV 4x4 rear driveshaft? That would be my advice. I'm not familiar with the 81's but they may have split the shaft and thrown in a center bearing for some reason for those couple years.
PostPosted: Mon Oct 27, 2003 5:01 pm
thanks alot for the help....the 81's are all togather different..i can't find a driveshaft close to me.... i one in the bed of the truck has a broke yoke and either need another end or another whole shaft.
thanks alot 804x4
