It is currently Sun Jun 07, 2026 11:21 pm
 Post subject: rear diff
PostPosted: Wed Oct 03, 2012 11:00 am
i was wondering if the rer carrier is interchangable on these luv's, my current carrier has welded spider gears and i am wanting to just throw my ring gear onto another but i cant find anything in the service info or factory books thats says if they can be swaped or not
 Post subject: Re: rear diff
PostPosted: Wed Oct 03, 2012 12:18 pm
I can't speak for 1st-gen LUVs, but you didn't say what you're driving. On the 2nd-gen LUVs the whole assembly comes out and you should probably replace it as a unit since they develop wear patterns. New gears are no longer available. I had to find mine on the salvage market.
PostPosted: Wed Oct 03, 2012 4:34 pm
Both 1st-gen and 2nd-gen Luvs have removable carrier assembleys. Ratios --4:56, 4:10, 3:73, through 1980. Don't know beyond that.
PostPosted: Thu Oct 04, 2012 8:05 am
After '80: 3.42, 3.73, and 4.10. I don't know if they're interchangeable with the earlier ones.
PostPosted: Thu Oct 04, 2012 8:57 pm
thank's everyone, i have a 81 luv and it all comes out as one unit, it's just the only one iv been able to find to buy is from a 75, im hoping they will match up and be able to swap, if my axles will splin into the side gears and the ring has the same amount of bolts with same spacing all should be good right?
PostPosted: Thu Oct 04, 2012 9:52 pm
I don't know about compatibility between 1st gen and 2nd gen. The 2nd gen (what you have) is the same as an Isuzu P'up, and if you want to look for a later model set, let me know. I have some contacts.
PostPosted: Thu Oct 04, 2012 10:25 pm
Just be aware that the gear ratio will probably be much different than yours. My 74 had a 4:56 ratio as stock.
PostPosted: Fri Oct 05, 2012 8:23 am
They are all 10-bolt Isuzu rears with 17-spline axles through '87 & the 3rd members should interchange (sometime after '88 rear antilock brakes added a sensor ring and the 3rd member housing got bigger & won't fit to the older axle housing). '81 has 4.10 gears, a '75 probably has 4.56 gears. There is one other thing to watch for, on certain years the bottom two studs passenger side are much longer, the housing some years was cast differently in this area. The 3rd will still interchange you just have to use the correct length studs- or bolts- to mount it, they are 8mm. I just have two bolts of each length & use whichever length matches the housing.
PostPosted: Tue Oct 16, 2012 8:49 am
thank everyone, i found a store called "six states distributors" that sell parts for the diff's and they agreed they said their books all say they are the same
PostPosted: Tue Oct 16, 2012 11:01 am
Then get the latest one you can. Don't get one that's older than yours.
