It is currently Sun Jun 07, 2026 10:11 pm
 Post subject: timing
PostPosted: Fri Sep 28, 2012 1:26 am
Hi
has anyone advance the cam 3-4deg.?? thanks
 Post subject: Re: timing
PostPosted: Fri Sep 28, 2012 1:03 pm
I did on accident on my 89 pickup. The 4z engines use timing belts, mine was off a tooth which was equal to 4 degrees. My motor isn't BRAND new, but it's not worn out either. going down the highway is torture and I ended up blowing out the crank seal housing gasket. Expect good power from 1500 to 2500 and then it stops. I wouldn't recommend doing this unless you have a brand new engine with really good rings or if it's a trailer queen
1980 LUV 4wd 1.8, 31's, 3" body lift, weber 32/36, header, fakemaster, project in progress
1989 Isuzu Pickup 4wd 2.6, 2.3 head, weber 38, header, flowmaster, 31's, DD/light wheeler
1989 Camry, the race car
1968 Ford Fairlane Fastback, next in line
Users browsing this forum: No registered users and 73 guests
