It is currently Sun Jun 07, 2026 11:20 pm
PostPosted: Tue Sep 11, 2012 2:40 pm
so i have an 81 luv and just replaced the head gasket about 2 months ago. i got it all put together, and i removed al the smog stuff. but now when i start it it run ok until i give it gas then it runs like crap. the suction in the carb is chopy and gets worse when i give it gas. any help would be great cause i start school in about two weeks and this is my only ride.
1981 Chevy LUV 4x4, Weber 32/36, emissions delete, custom gauge bracket, and cd player.
Image Image
PostPosted: Tue Sep 11, 2012 4:52 pm
I would guess that it has to do with removing the smog equipment. Check for vacuum leaks.
PostPosted: Tue Sep 11, 2012 9:40 pm
i forgot to mention it also dosent like to idle very well
Image Image
PostPosted: Wed Sep 12, 2012 11:41 am
Take a can of carb cleaner and spray it at the base of the carb and on the hoses to check for vacuum leaks...if idle changes...you have a vacuum leak!
PostPosted: Fri Sep 14, 2012 7:47 pm
ok so i checked for all possible vacuum leaks and came up with nothing. so now when i hit the throttle it tries back fire out of the carb correct me if im wrong but isnt that a timing issue???i would take it to a shop but i cant afford it
Image Image
PostPosted: Sat Sep 15, 2012 11:12 am
Did it run good for the 2 months after the head gasket?
PostPosted: Sat Sep 15, 2012 12:39 pm
nope i havent been able to get it to run good since the new head gasket was installed
Image Image
PostPosted: Thu Sep 20, 2012 2:11 am
Not to disparage the work you have done but I would first make sure everything got reinstalled correctly. Assuming that it is correctly installed it sounds more like a carb issue. Go back to basics. You have checked for a vacuum leak, look for correct vacuum hookups and then adjust the carb from scratch.
PostPosted: Thu Sep 20, 2012 11:50 am
Assuming that all vacuum lines are connected properly, no vacuum leaks like already said, I would definately recheck the cam timing. May have installed the chain one tooth off time, and it will run crappy that way.
PostPosted: Thu Sep 27, 2012 6:39 pm
thank you all for all the info i will be doin some work on it this weekend.
Image Image
PostPosted: Mon Oct 15, 2012 5:33 pm
ok so my carb was shot, so i got a webber. now after everything i did i have to remove the head all over again. cause i have two burnt valves :cry:
Image Image
PostPosted: Tue Oct 23, 2012 12:41 pm
im finally gonna get my truck back on the road. the head is in the shop, so ill have it done by this thursday i cant wait!!! :D
Image Image
PostPosted: Sat Oct 27, 2012 6:43 pm
my truck is finally back in the road!!!!!! :ebiggrin and its runnin better than when i first got it
Image Image
