It is currently Wed Jul 01, 2026 9:56 pm
 Post subject: distributor
PostPosted: Mon Sep 17, 2012 12:55 pm
can you convert the 1.8 to a hei if so what has to be done. or is there a different setup?
1981 Chevy LUV 4x4, Weber 32/36, emissions delete, custom gauge bracket, and cd player.
Image Image
 Post subject: Re: distributor
PostPosted: Mon Sep 17, 2012 1:00 pm
Try using the Search button at the top of the page.
Use the key words.........."dizzy swap"
PostPosted: Mon Sep 17, 2012 1:08 pm
Also search pertronix.
PostPosted: Mon Sep 17, 2012 1:14 pm
Also look in the information section on the main page under 'electronic distributor swap.'
PostPosted: Mon Sep 17, 2012 1:23 pm
The HEI conversion is more than twice the cost of the Pertronix solution, and obviously it's a more significant re-wiring exercise. I think the HEI mod requires a whole new distributor assy. I think the HEI route is a bit overkill for the stock engine. Does anyone running it feel otherwise? Why?
PostPosted: Mon Sep 17, 2012 5:57 pm
i am running an 95 isuzu pup electronic distributor from the 1.9L and i love it, it gets rid of the issue with burning and adjustring the points and as far as i understand it provides a more consistant and powerful spark, i wind my motor to 6k and dont have any issues with misfiring.
all it takes is the pup distributor, i bought mine from rockauto right now their cheapest is 150 but i paid around $70 for mine so keep an eye on that they get new stuff often. also check ebay for one. you just run one wire to + and one to - on the coil and set the timing same way as the stock one and your done..
PostPosted: Thu Sep 20, 2012 2:04 am
I ran the setup from an 86 I-Mark for a while and it did make a noticable difference in my truck's perfomrance. It could rev as far as you had the courage to take it without the misfiring or point float. It was simpler for tune-ups and improved mileage a bit too. I got my entire setup from a wrecking yard for the $25 standard charge for a distributor. Was a danged fine upgrade for the price.
PostPosted: Sun Sep 23, 2012 4:41 pm
im running one from an 85 not 95 cant believe i missed that typo...
probably wont see a huge difference in power output on a stock motor but if you were running a really hopped up engine that needed a good powerful spark it would be a good thing to look into.. i swapped mine because i was having issues with my points not staying where they should have and i burned out a set way too fast and got tired of messing with it
Users browsing this forum: Google [Bot] and 42 guests
