It is currently Wed Jul 01, 2026 6:15 am
PostPosted: Sun Sep 02, 2012 4:04 pm
I repalced my alternator and my regulator, the gas pump is working if the regulator is disconected,
when i the ignition switch is in "ON" position i did not hear the pump but like i mentioned before once the regulator is disconcted the pump back to ON (regulator and alternator bran new)
Could be de ignition switch??
PostPosted: Mon Sep 03, 2012 8:38 am
check the relay..regulator controls the power for the fuel pump.
PostPosted: Mon Sep 03, 2012 3:43 pm
my relay was messed up so i jumped the pins with a litle wire and havent had a problem with it sence
if it aint a luv it aint shit
PostPosted: Tue Sep 04, 2012 12:45 am
You won't hear the pump run with the key in the "on" position. Pump only runs in the "start" position and then runs from the alternator/regulator when the engine is running.
PostPosted: Wed Sep 05, 2012 4:17 pm
Don't struggle with electrical issues on the LUV without doing the Fuse Box Fix.
Its cheap and easy and often the cause of issues that don't seem related.
Do a search.
PostPosted: Fri Sep 07, 2012 10:09 pm
New alternator, new regulator, new carburetor (rebuild), new ignition switch, still is not working the cars run for few seconds and then shut down when i disconect the regulator i have power in the carburetor, the relay pump also is new is another relay maybe i have to check i find three relays in the small box in the passenger side. I need help my wife said no more money to fix the car LOL..
