It is currently Sun Jun 07, 2026 11:08 am
 Post subject: How to "beef up" the 1.8
PostPosted: Mon Jun 11, 2012 4:54 pm
Hi Guys,
Well its another day which means another LUV project. I am looking into beefing up my 1.8 and making a little "hot rod" out of my 1980 2WD. I was curious as to what you would recommend doing to the motor to give it some get up and go. I am thinking Offenhauser manifold, Weber Carb, a header and installing a shift kit. What do you think? What has worked for you? I am not a big mechanic so I need some advice.
Thanks
PostPosted: Mon Jun 11, 2012 9:11 pm
Electronic ignition also. I am out of Offy intakes right now, but they are on order. Let me know if you ever are interested in one.
http://www.purerockradio.net/
PostPosted: Mon Jun 11, 2012 10:59 pm
Cam regrind. After that, it starts getting cost prohibitive when you think about the cost of a v8. :p
PostPosted: Tue Jun 12, 2012 2:16 pm
Thanks for the advice guys! I always appreciate it when some LUV Gurus's are willing to share their knowledge. How much do the Offenhausers run?
PostPosted: Tue Jun 12, 2012 10:43 pm
Well the intakes were $238 + shipping and insurance, but now with the 10% increase Offy just informed me of yesterday, it will probably be around $259. I won't know exactly until I get the order, but it should be about that. I will be posting updates along the way, so everyone will know when I get them back in stock.
PostPosted: Sun Jun 24, 2012 9:26 am
Something I noticed is that the main bearings are thicker for the G180 than they are on a Toyota 22R, which is considered one if the most reliable engines out there. I know from experience the G180 is a stout motor. The only issue I know of is that Isuzu out the cylinders a little too close together, and on the older headgaskets they can bridge, turning it suddenly into a 2 cylinder.
PostPosted: Sun Jun 24, 2012 9:27 am
