It is currently Mon Jun 29, 2026 9:46 pm
PostPosted: Thu Apr 19, 2012 4:59 pm
Well I bought a 1981 Luv because I needed an engine in mine that burnt a valve. Got the 81 truck for $350. Compression 130 on 2 cyls and 140 on 2. Got the 81 on Friday, started the swap Saturday and drove my 79 around with newer engine today!
My 79 had a weber so there is some carb wiring to figure out. Specifically a 4 pin connector that I have nothing to connect to. Anyone know what this is? I have the Series 9 wiring diagram and can chase it down but if someone cares to let me know I would appreciate it.
PostPosted: Sat Apr 21, 2012 4:37 pm
The only wire from the 4 pin connector that I had to use was for the automatic choke on the weber. On my '78 it was the blue wire I believe.
PostPosted: Sun Apr 22, 2012 9:45 pm
The carbs will swap ..right? I think that would be easier and faster than wiring on the newer carb!
PostPosted: Mon Apr 23, 2012 5:04 pm
I think you lost me. Either carb will work, but with the '81 you'd have to reference the manual to see if the wiring is the same.
PostPosted: Tue Apr 24, 2012 8:00 am
Use the carb originally for the vehicle.
Users browsing this forum: Majestic-12 [Bot] and 70 guests
