It is currently Mon Jun 08, 2026 3:05 am
PostPosted: Wed Sep 21, 2011 10:24 am
So I had it running really good than I put new plugs wires cap and rotter and I have the firing order of 3 an 4 wrong now the wires are right and ithas no power and spudders any ideas cause I'm lost!
PostPosted: Wed Sep 21, 2011 12:23 pm
Check your fuel filter.
PostPosted: Wed Sep 21, 2011 12:37 pm
Still have points? I would check the gap.
PostPosted: Wed Sep 21, 2011 8:59 pm
are you sure its running on all 4? Might try putting the old wires back on if its not. Rare, but you could have a bad new wire.
PostPosted: Wed Sep 21, 2011 11:33 pm
What firing order are you using?
PostPosted: Thu Sep 22, 2011 4:23 pm
Check your vacume lines. When I changed my wires, I accidently bumped a vacume line, it came off, and it ran like crap, wouldn't even idle.
1974 Mikado 4x4 50,000 orig. miles
PostPosted: Sat Oct 01, 2011 10:02 pm
i have replaced the fuel filter and i just put a new weber 32/36 on it.. it back fires tru the carb the only time it dosnt is when the timing is so retarted it dosnt even idle smooth at all im gonna check and see if maybe the distributer is in wrong maybe cause it has to be timing of some sort cause it ran like a champ before i changed wires
PostPosted: Sat Oct 01, 2011 10:04 pm
an the firing order is the one i found on here 1342
PostPosted: Sat Oct 01, 2011 10:05 pm
what should the points gap be?
PostPosted: Sat Oct 01, 2011 11:10 pm
.018 - .022 for 72-75, .018 - .020 for 76-80
Firing order 1-3-4-2 for all (as you said)
Timing 12 BTDC at 700RPM for 72-75
Timing 6 BTDC at 900RPM for 76-80 with vac adv plugged
Did you change the plugs too? Did you gap the plugs too far? Spark gap should be .030 for stock ignition. Did you switch to platinum plugs?
PostPosted: Sun Oct 02, 2011 11:22 am
yes i changed the plugs but i put the copper core ngk's back in it
PostPosted: Mon Oct 03, 2011 4:50 pm
Double, triple check the firing order. As had been said, 1 3 4 2 and the distributor rotates to the left.
PostPosted: Mon Oct 03, 2011 10:10 pm
that was what i had wrong im used to the firing rotation on a normal v8 being clockwise and these motors are counter clockwise my bad she runs like a brand new truck now thanks for all your help....
PostPosted: Mon Oct 03, 2011 10:15 pm
:smt023
