It is currently Mon Jun 08, 2026 4:15 am
PostPosted: Sat Oct 22, 2011 11:58 pm
Voltage across the battery reads 15.99 at idle and climbs when given gas to about 16.39. I guessing that's no good. Is there a way to adjust regulator on these trucks? Looks to be fixed to me, however manual says to adjust if reading are incorrect....? Is there a better way to test these regulators?
PostPosted: Sun Oct 23, 2011 9:56 am
Nope, if it keeps climbing it's a bad VR, you need to replace it. I just did mine for the same reason, RockAuto has good prices...,
http://www.ehow.com/video_4874557_test-car-voltage-regulator.html
PostPosted: Sun Oct 23, 2011 11:11 pm
The stock Luv regulator is indeed adjustable, however it is somewhat complicated and difficult to explain how. I believe the new replacement would be solid state now, so no adjustments.
I agree with just replacing it.
PostPosted: Fri Oct 28, 2011 6:59 pm
order came in today from rockauto...looks to be quality part
ordered AIRTEX / WELLS Part # 1V1079
was sent:
wells VR743
MADE IN JAPAN! only $10.44!
I also ordered new starter brushes and condenser/capasitor for the VR (radio ignition interference capacitor) . Total including shipping was under $24 :D
