It is currently Wed May 13, 2026 8:31 pm
 Post subject: Oil in air cleaner
PostPosted: Wed Jul 13, 2011 11:59 am
I'm stumped. I can't seem to find how I'm getting oil into the air cleaner. I have fresh oil under the air filter.
76 LUV
 Post subject: Re: Oil in air cleaner
PostPosted: Wed Jul 13, 2011 1:09 pm
It is called blow by..
PostPosted: Wed Jul 13, 2011 2:07 pm
+1 ^
PostPosted: Wed Jul 13, 2011 4:48 pm
How do I stop it. This just started a few months ago.
76 LUV
PostPosted: Wed Jul 13, 2011 6:05 pm
New pistons and rings.
PostPosted: Wed Jul 13, 2011 7:24 pm
You have pressure escaping past the rings and building up in the crankcase then escaping through the breather....(Blow BY).
I have gotten by with a few with just rings...and the rest of the rebuild kit, Rod and Main berings etc. You won't know for sure if you need to replace pistons until you get into it. My philosophy is if I need to replace pistons I might as well have the block bored to the next size so tolerances are as tight as new.
2005 Silverado 3/4T Crew Cab
1981 Luv 2WD
1995 Roughneck JetBoat
1981 Luv parts trk
PostPosted: Thu Jul 14, 2011 3:22 pm
And if you tear it apart spend a little more and get the valves done..if you can have the valve guides machined for vitron seals instead of the umbrella seals.It will help oil control later on and keep the valves from building up carbon on them from the oil and exhaust.
Users browsing this forum: Bing [Bot] and 28 guests
