It is currently Mon Jun 08, 2026 3:04 am
PostPosted: Sat May 28, 2011 7:13 pm
I put a 76 body on a 80 4x4 chassis. The 76 has the hydraulic clutch pedal assembly and the 80 transmission has the mechanical setup. Has anybody ever done this before. I need to alter the pedal from pushing in the master cylinder to pulling the cable. does anyone know if the clutch pedal from a mechanical clutch cab will bolt up to the cab I have. Any ideas will be appreciated. thanks
PostPosted: Sat May 28, 2011 7:48 pm
Why not keep the hydraulic pedal assembly and add a slave cylinder to the clutch? I did this for a diesel swap.
See this thread.
Good luck,
Eric Q.
My build thread.
PostPosted: Sat May 28, 2011 9:13 pm
I have a bell housing from a hydraulic clutch transmission that should convert your "new" transmission to hydraulic. Someone else expressed interest, and I think I owe him some photos...but if he doesn't want it, it's available.
viewtopic.php?f=8&t=24426
I've now posted the photos.
PostPosted: Sun May 29, 2011 12:14 am
Also, keep in mind that newer trucks (80ish?) had a cable clutch.
PostPosted: Tue May 31, 2011 10:13 am
He has not replied to my email, so this is still available.
PostPosted: Tue May 31, 2011 10:26 am
I have had a lot of trouble with the hydrualic clutch on my 77. I have even though about converting it to mechanical. I would look around at the newer mechanical parts and see what you can do.
PostPosted: Wed Jun 01, 2011 8:49 pm
pedal asy. will interchange then you have to drill the firewall in the right location and your done.
PostPosted: Fri Jun 03, 2011 8:42 pm
Well I finally decided what to do with the clutch. I installed the pull type slave cylinder and the clutch cable on a bracket and mounted it on the driver side wheel well. Now the slave cylinder pulls the cable so I got to keep the stock pedal and master cylinder and it actually seems to work really well.
PostPosted: Sat Jun 04, 2011 9:40 pm
Good work. Kind of like a hybrid. :lol:
My build thread.
PostPosted: Sun Jun 05, 2011 10:54 am
Well done it's that kind of thinking that puts you a head of the class. Keep up the good work.
