It is currently Mon Jun 08, 2026 10:28 am
PostPosted: Mon Jun 13, 2011 8:36 pm
I am in the middle of replacing my head gasket and I am thinking of doing a smog delete need to know if it will still pass the
the pipe test. Every body keeps telling me they don't do visual inspections any more is this true? Can I put a weber on and still pass if they do visual?
PostPosted: Tue Jun 14, 2011 1:54 am
I live in az what yr is your truck my 72 i had yrs back had a webber on it passed no problem.
LIVE HARD PLAY HARDER
PostPosted: Tue Jun 14, 2011 8:45 am
1977 2 wheel drive with 1.8L.
Did you also delete the smog equipment,
Or just add the weber with all the same vacuum hoses?
PostPosted: Sat Jun 18, 2011 1:24 am
Mine didnt have one but the yr you have still requires it. you can run the webber juat attach your vacum line tune and when it passes get the 5 yr tag
PostPosted: Sun Jun 19, 2011 12:37 am
I live in AZ and have a '79 with a stock carb and it passed no problem. They did fail me in January 2011 for having a piece of masking tape on the vacuum hose though, they said that it could be covering a hole (it was there from a head gasket replacement job years ago when I marked all vacuum lines so that they went back in the proper places). They said take the tape off and go back through the line right then. I did and they passed me 15 minutes later. So I guess that in my case, yeah, they did check it out visually. I don't see why they would fail you for having a different non stock carb on if it passes emissions OK though.
PS they did fail me years ago for a "bad" gas cap. got a new one and it passed fine.
Users browsing this forum: Google [Bot] and 25 guests
