It is currently Wed May 27, 2026 10:59 am
 Post subject: Revving problem
PostPosted: Thu Apr 21, 2011 8:08 pm
When I push in the clutch to shift up, the engine revs a couple hundred RPMs higher than when I let off the gas. Any ideas?
1980 LUV 2wd - More pounds in rust than torque
1994 Jeep Cherokee 4x4 - Lifted with lights ;)
 Post subject: Re: Revving problem
PostPosted: Thu Apr 21, 2011 9:54 pm
Australian LUV Guru
Is it a Cali Truck?
Try pulling the wires off the switches operated by the clutch pedal and joining together. CAUTION you may disable neutral start switch.
1980 4x4 KBD40 ISUZU/Chev Luv
PostPosted: Thu Apr 21, 2011 10:29 pm
So far as I know, it's an Oregon truck. I'll give it a try. It's weird though, cuz it just started happening a couple days ago.
PostPosted: Fri Apr 22, 2011 12:48 am
Australian LUV Guru
:lol: Welcome to Luv Truck ownership :lol:
PostPosted: Fri Apr 22, 2011 9:32 pm
Haha. That's what I hear. At least it gives me cruise control at low speeds! What is the normal idle speed? When I first start it up, it idles at about 700-800 rpms. When It's running and finally does slow down from 2500, it'll stick at about 1300 rpms. I haven't gotten a chance to check the clutch sensor thing. That's the one that's up under the dash on the clutch pedal, correct?
PostPosted: Tue May 10, 2011 11:05 am
Check for vacuum leaks.
PostPosted: Tue May 10, 2011 12:17 pm
The throttle linkage on the carb may be sticking, not letting it return all the way. Lube it with WD-40, inside & out. Also make sure your return spring is strong enough or maybe broken or missing since it just started happening.
Users browsing this forum: No registered users and 67 guests
