It is currently Wed May 27, 2026 2:46 am
 Post subject: Oil Pressure
PostPosted: Thu Apr 07, 2011 10:24 am
Stupid question, my truck is running 70 Psi cold but quickly goes down to 45-50 psi when it warms. Does anybody know what the factory oil pressure specs are.
 Post subject: Re: Oil Pressure
PostPosted: Thu Apr 07, 2011 10:58 am
I don't know the factory specs, but out on the highway running 70, mine holds 60 psi.
PostPosted: Thu Apr 07, 2011 3:25 pm
mine at idle holds just a hair below 20 at 700 rpm when at 170 degrees.... anybody else like this?
PostPosted: Thu Apr 07, 2011 5:23 pm
Spec is 57lbs warmed up and cruising say 3000 rpm. Anything above 10lbs at idle is fine, the oil warning light will come on at about 7lbs or less.
PostPosted: Thu Apr 07, 2011 6:48 pm
I was always told most engines are fine with 10 PSI per 1000 RPM. However, I like to see it about 20PSI at idle.
PostPosted: Thu Apr 07, 2011 9:26 pm
good show... glad I could get some answers and it makes me feel a little more at ease.
Users browsing this forum: Google [Bot] and 61 guests
